Results 1 to 19 of 19
Thread: Travertine coping design question - 12x12 or 12x24?
    Sep 2015
    Tucson, Arizona
    86
    Went to order travertine coping, and learned we can get it in either 12x12 or 12x24 sizes, with price being exactly the same per foot. We have geometric pool and spa. My initial instinct is bigger is better so there will be fewer joints, but whichever size we go with will still require cutting some pieces to go around each 90 degree and 45 degree angles. I'm not sure if the small corner cuts will blend in more if we use only 12x12 on the long runs between corners or if it will matter at all. Decking will be the same travertine in a 4 piece French pattern. Any opinions on whether to use 12x12 or 12x24, or a mix of both?
    Owner Build. 32x16, with 6x8 raised spa. Broke ground April 1, 2016, swimming July 18. Pentair Intelliflo VS + Whisperflo for Water features; Clean & Clear Filter 420; Master Temp Heater 400k BTU; Intellibrite 120V pool and spa lights; Regular ol' plaster.
    SuzfromTexas's Avatar
    Apr 2015
    Houston, Texas
    3,217
    Re: Travertine coping design question - 12x12 or 12x24?
    Do you have a build thread with the design of your pool? Or can you post one here? Without seeing anything, I would say the 12x24. I don't think I'd like mixing the two different sizes for the coping.
    Suz~Cypress area~ 2015 pool build. 23K gallons. IG swcg system. 35'x18'; 573sf; 104' perim; depth 4'-7'. Bubblers, sheer descents, 7' spa. Jandy: color LEDs; 2HP 2sp pump; 1HP 2sp pump; spa pump; 580 cartridge; 400K BTU; Dolphin M500; PS8; Inline chlorinator not used; Aqua Pure 1400. Blue Granite Sheen. Travertine deck. Lightstreams Peacock Blue TF-100, K-1766, SpeedStir
    Sep 2015
    Tucson, Arizona
    86
    My build-thread
    http://www.troublefreepool.com/threa...Advice-Welcome!
    And a pdf of just the pool plan:
    Attached Files Attached Files
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    +1 on the 12x24.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Apr 2015
    Houston, Texas
    3,217
    Thanks for the link and pdf. After seeing those, I'll stick with my 12x24 vote. They will make the long sides look longer which I think is a good thing - anything to fool me into thinking I have a bigger pool! Lol!
    BTW, I love the design and that great view you have!
    Nov 2015
    Woodland Hills, CA
    176
    Mine was 16x24.
    More important to me was the thickness since so much is exposed as coping. I used was 2" Best pics I can come up with:
    O/B Woodland Hills, CA : O/B12x30 inground with 6x6 10-jet spa, 10,500gal, 6' Baja deck, 42" spillway, All Jandy: 400k heater, 2.7 HP VS pump, 1.5HP booster spa pump, SWG, Intellelink controls, (4) LED lights, cartridge filter and BlueSquareQ360 infloor cleaning system, Eclipse drain, glass tiles, Zanzibar white pebble finish. Broke ground 2/18/2016, completed 8/16/2016. TFT 100 kit.
    Apr 2016
    Porter Ranch, CA
    82
    Do you have gunite/shotcrete yet? How thick are the walls? I'm also looking for coping and my walls are 12" in some places. It seems like you would want the coping to completely cover the Gunite while allowing for the cantilever edge. So, it seems like 12" would not be wide enough?
    Completed 8/26/16: Rectangular pool 42x20 and spa 10x8, 27,000 gallons, IG, Pebble Tec (Sheen) White Diamonds, Hayward 700sq ft. cartridge filter, saltwater cell, (3) Hayward Ecostar VS pump, 500k heater, (2) 2' Sheer Descent, 3 Hayward Colorlogic pool lights (+1 spa), 2 Colorlogic 320 lights (Baja/water feature), Omnilogic automation, TF100 Testkit
    New Pool Build - Porter Ranch, CA
    Sep 2015
    Tucson, Arizona
    86
    Shotcrete is done. The bond beam is roughly 12"-13" wide, so you are correct that 12" wide coping won't completely cover the cement bond beam. Does it need to? We'll have more travertine decking abutting the coping which will cover (but not be cemented to) the bond beam. It seems like I have seen lots of pools with various pavers that can't be wider than 12" and so the initial run of pavers probably doesn't cover the bond beam. I wonder if this is really an issue?
    Apr 2016
    Porter Ranch, CA
    82
    I'm with you so let's hope someone else weighs in. I just wondered if maybe the bond beam wasn't 12" in other states due to varying codes, etc. I'm going to have the same thing with my travertine deck. It will be sand-set and butt up against the coping. Currently I'm just planning on the same 1.25" thick pavers from the deck for a nice, clean, uniform look.
    Apr 2015
    Houston, Texas
    3,217
    I had to look back at my build thread to remember about my coping on the bond beam. Yes, I did have bond beam sticking out from the coping. If interested, the deck work begins on page 25 of my build thread.
    Here's a picture - you may have to zoom in.
    Kpag's Avatar
    Feb 2015
    Dallas TX
    159
    I thought you are NOT supposed to have decking on the bond beam. The expansion joint between the coping and the decking should be a true joint that goes all the way through which isn't possible when decking is on the bond beam.
    IG ~12000 gallon 1988 freeform pool with IG spa, Hayward equip, Ecostar pump. Remodel done: NPT Arctic 1x2 tile in Lagoon w/ gray thinset & Light Pewter grout, French Gray PebbleSheen w/ grey fittings, Leuders buff eased edge limestone coping w/ Light Buff mortar, buff mastic
    Apr 2015
    Houston, Texas
    3,217
    Quote Originally Posted by Kpag View Post
    Oh my, I hope not?!! Kpag, what does that mean to my pool?
    Kpag's Avatar
    Feb 2015
    Dallas TX
    159
    Suz, don't let me panic you; I don't even know how to test our water. I get all my info from the internet like the pics in the attached article below. I know our coping is 4x9 brick and half of the quotes we had to remodel were adamant that we needed to cut our deck back to the bond beam and half said it didn't matter.
    Swimming Pool Construction Company | Commercial Pool Contractor | Serving Maryland (MD) and Virginia (VA)
    Nov 2015
    Woodland Hills, CA
    176
    My bond beam was 12". So were the raised walls of my spa and that is why I went with 16" wide, because I ended up with two inches overhang on either side of the spa for a balanced look. On the pool, we built up two inches of mortar on the back of the bond beam to support the end of the coping. Because of the seismic activity around here, I wanted the deck decoupled from the coping.
    Nov 2015
    Woodland Hills, CA
    176
    OP; my decking is the Versailles French pattern - check out the pictures.
    Everything is in multiples of 8" - 8" 16" & 24". There is no 12", so in answer to your question about what would blend the best, I guess 12x24 because it kind of matches, but 16" is the sweet spot.
    philboyj's Avatar
    Jul 2015
    Houston TX
    326
    We used 12 x 12 coping and a versailles pattern deck of the same travertine / marble material. I think you cannot go wrong with either coping size. Here are a couple of pictures:
    Geometric pool with all Pentair equipment. Raised spa - 18" with Artic Lagoon 1" glass tiles. 3HP VS Pump, 2 skimmers, 6 returns, IC40 Salt system, Easy Touch 8 with LED color light in pool and spa. 1200 sqft of Marble White Pavers decking in Versailles pattern. Tiling and coping almost completed, Indigo Blue Prism Matrix plaster. Pool Build Thread: Houston (Katy) Pool Build - Started April 2016
    Nov 2015
    Woodland Hills, CA
    176
    That ^ looks good!
    Sep 2015
    Tucson, Arizona
    86
    As an update - this ended up being a moot point for us. The vendors that told us they could deliver 12x12 or 12x24 ended up being unable to do either. Maybe there was a supply shortage in Arizona for scabos travertine coping - my neighbor was ordering his at the same time and had to get his shipped in from a Las Vegas vendor. We eventually found a Phoenix vendor with material in stock, but only in 16x24 size, so we went with that. I guess we lucked out, since this size hits Frank Rizzo's "sweet spot" theory and earthquake protection theories above.
    Nov 2015
    Woodland Hills, CA
    176
    Quote Originally Posted by azdesertpool View Post
    Sweet
