Thread: My PH went down after adding Borax?
    Jun 2012
    Smithtown, NY (Long Island)
    65
    Just got my pool up and running a few days ago and tested the PH, which was on the low end (about 7.2) so I added about 3.5 lbs of Borax yesterday into the skimmer. I checked the levels this morning and the PH went down a little. I've never had a this problem before so not sure what my next step is. My levels are below. Alkalinity is a bit low so maybe i add some baking soda first? I did have the heater running yesterday after putting the borax in but I'm not sure if that would be the cause. Any tips would be appreciated.
    FC 3.4
    CC 0
    PH 7.1
    AK - 55
    CH 75
    CYA 0 (will get that up to 50)
    ~30,000 Gallon Free Form Pool; IG; Vinyl; DE Filter; Installed 2005
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    Re: My PH went down after adding Borax?
    I think I'd bring the TA up first, see how it and PH stands, then add borax as needed. Maybe to around 70 initially. Mine stays happy and stable around 60 but I also never had a low PH since dropping pucks and going SWG 7.2-7.1 though is on the low end where I think it's had to read anyway and also off some, could have been lower than it looked before or a little higher now. Anything else added that could be lowering PH? I'll be interested in seeing the more expert responses as well though, if not just a little variance being so low and hard to test I'd be wondering the same thing!
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    Jun 2012
    65
    I added 10 lbs of Baking Soda which upped my AK to 75 as expected. My PH also went up to about 7.5 without having to add any more Borax. I'm not sure if that increase was a result of just the Baking Soda, or if somehow increasing the AK allowed the Borax effect to kick in. Either way, I will continue to monitor levels daily for awhile to make sure they stay consistent.
