Thread: Pentair SD80 sand filter leak
    Just found my sand filter leaking and after checking all the connections found the leak coming from the bottom.After vaccuming all the sand out and removing the shell found the bottom seam pulled apart!!
    Anyone ever seen this or have any idea what could cause this??
    24'x40' 35,000 gal inground true L ,Vinyl Liner,Brick coping,Concrete Deck
    Aqua Logic P-8 with Compupool T-15 SWG
    Hayward Ecostar SP3400VSP,Pentair 1.5 HP Booster Pump
    Pentair Legend Platinum Pool cleaner
    Glacier Pool Chiller
    Jun 2014
    15,198
    Re: Pentair SD80 sand filter leak
    Sounds like a manufacture's defect. I've seen a couple other similar posts this year. You might want to call Pentair with your model and year of purchase. Perhaps they'll help you out?
    I have called Pentair and started a case,will keep updating here,wish me luck!
