Thread: Summer covers? Leaving for vacation, need a summer cover that doesn't heat up.
    May 2016
    AUSTEX
    52
    In theory, I think I need a white bubble cover to "close" my pool for the summer (Texas). Can't seem to find any answers online, but there has to be a need for summer covers, here, AZ, FL. Any ideas?
    18,000 gal, IG kidney w/ spa, Pebbletech, 60 DE filter, 2 skimmers, auto chlorinator, 2.0 hp pump, Dolphin M400
    Mar 2016
    Easley, SC
    380
    Re: Summer covers? Leaving for vacation, need a summer cover that doesn't heat up.
    I am also searching for something to cover my pool when I go on vacation... Mostly to keep the leaves out as I would like to keep my pump running on a timer while I'm out of town. Will let you know if I come across anything.
    18x36 inground / 28k gal / Phanton vinyl liner (replaced in 2009) / Hayward Pro Series sand filter / Hayward 1hp pool pump / Hayward 3/4hp booster pump
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    The standard light blue covers are probably the most available and actually best suited for not trying to gain as much heat as a clear cover. If you leave a standard blue cover on all the time and only run the pump in the early morning, late evening or at night, you'll minimize heat gain as well as block most UV during the day. The thinner the better to minimize heat gain. I would periodically take the cover off overnight to allow heat loss and allow the pool to outgas a bit. There are those space age covers, but I believe they are always 12mm and designed to retain heat.
    Isolated Spa - 345 Gallons
    May 2016
    AUSTEX
    52
    It would seem like the aluminized radiant barrier material used in attic applications would work for this application as well. There's probably a good reason why it wouldn't, but it beyond my understanding.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Any solid cover will help the pool retain heat by reducing evaporation. Unless it completely blocks light, you will get algae growth. There are black covers that are intended to go under winter covers to block light.
    Not really much value in covering the pool. Just keep it chlorinated either by shocking before you leave or having someone dump a gallon of bleach every couple of days and clean up the result when you get back.
    May 2016
    AUSTEX
    52
    Quote Originally Posted by JohnT View Post
    Being an engineer, I tend to overthink these things, however, being a neophyte pool owner, I don't want to do something stupid either. Going back to the aluminized radiant barrier, wouldn't it block light as well as keeping the pool from heating up, at least that's how I see it. Wrong?
