Results 1 to 9 of 9
Thread: Algae or dirt? Sorry long post
    Diane T.'s Avatar
    Apr 2015
    Alabama
    55
    History, had this in April, a month ago, and showed up again two days ago. Slammed both times. They are building a new house behind me and the first time it started had cleared the lot and removed many many trees. Last Thursday and Friday they brought in that nice red dirt and did the final grade. I want to think it's dirt etc., but could be algae. It shows in the same areas (dead spots?) along the top edge of slope. The water was a little hazy Friday, clear yesterday until I brushed. Water has never been green, but is naturally a turquoise hue. My FC has never been below 6 except the very first time it was 4.
    Today
    FC 9.5
    CC 0
    PH 7.5
    TA 70
    CYA 60
    I did the OCLT last night zero loss. I have never had any FC loss with this stuff. CC always zero.
    I did lower the Ph a little yesterday and bumped the SWG up. Brought it up from 8.
    Tried to attach a photo but says it exceeds ??
    This stuff collects around the edge slope in a few spots and a little on steps. Looks slightly green yellow. It does collect on the bottom also in varied amounts, but isn't visible until I brush. Mostly brown dust when I brushed yesterday. Haven't brushed yet today.
    My only conclusion if not dirt mustard algae.
    Of course I have company coming Saturday and don't want to SLAM right now, especially to mustard level. My FC takes forever to drop.
    Any opinions. I'll try to get a photo on here.
    IG 15,000 gal vinyl Grecian SW, Hayward SWG, Pentair whisper flow pump, sand filter, Aquacal ice breaker heat pump. Finished August 2015, screen enclosure, TF 100
    Diane T.'s Avatar
    Apr 2015
    Alabama
    55
    Re: Algae or dirt? Sorry long post
    Jul 2015
    Central Valley CA
    1,109
    I would bet dirt. My lot is all dirt (no Landscaping yet) and I get the same look when wind kicks up, get in and feel it if it is gritty it's dirt, if it is slimy it's algae. If you don't have a vacuum hose to connect into your skimmer you can do what I do, run the pump and brush as often as you can stand it, try to keep the particles in suspension so the filter can remove it. If I brush 3 or 4 times a day when it gets bad I can usually clear it in 2 or 3 days.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Diane T.'s Avatar
    Apr 2015
    Alabama
    55
    Thank you for the advice. I did my best to feel this stuff. It is really fine, but did not feel slimy. Had to use my toes.....so.
    Vacuumed and brushed twice. Just a slight haze to the water in the deep end. I will keep the FC on the high end and hope they sod that yard soon!
    Diane T.'s Avatar
    Apr 2015
    Alabama
    55
    Haven't seen any progress. Brushed for times yesterday. What I can feel on the steps does feel gritty, but looks greenish. Super fine. Pump was off overnight and when I brushed a good amount of dusty brownish sometimes green puffs up. Water slight haze. FC was 11.5 at 9 am from a 10.5 yesterday afternoon. SWG off at 5 pm. Not a legit OCLT, but still not seeing any FC loss. Stumped. Still dirt settling? Lowered ph preparing to SLAM after I recheck FC. Any help experienced thoughts out there?
    FC 11.5
    CC 0
    CYA 50 made husband confer
    PH 7.7 ? With FC over 10
    TA 70
    Susiejax's Avatar
    May 2016
    Fort Wayne, Indiana
    50
    I would guess dirt as well. I usually get dirt deposits at the top of the slope, in the dead corner of the deep end and sometimes near the stairs. It gets worse when the farmer next door does his tilling and planting. I've learned to live with it, and vacuum it away. When I brush, it does puff up and then settle back down in a few hours.
    I wonder if my sand has trouble filtering it out, since it is so fine.
    When I used to go the pool store for water testing, my "Dissolved Solids" was always kind of high. (They never really explained what that meant, I wonder if it means DIRT)
    Good luck!
    22,400 gal; in-ground gunite rectangle, vinyl liner; 3.5'-8' depth; Chlorine; auto cover; Hayward Pump and Sand Filter; Hayward Electric Heatpro; diving board; 3 sidewall fountains; open mid May thru mid October; built 2011; Taylor K-2006C FAS-DPD Test Kit
    Diane T.'s Avatar
    Apr 2015
    Alabama
    55
    Does your water get hazy/milky too? I can still see the drains fine.
    Susiejax's Avatar
    May 2016
    Fort Wayne, Indiana
    50
    Quote Originally Posted by Diane T. View Post
    I have not had a hazy water problem since switching to TFP. My water was very milky when I opened it this spring, but I SLAMed it and haven't had a problem since.
    Diane T.'s Avatar
    Apr 2015
    Alabama
    55
    I give, Slamming dirt and/or algae. I told my company to bring old bathing suits!
