Thread: Pump not shutting down after testing SPA
    May 2016
    Fernandina Beach
    4
    Please excuse my ignorance, but I am a true novice to pool maintenance. Since I am expecting guests, I wanted to ensure that my SPA (attached
    to pool and connected via a waterfall) was still working properly. I had last used it in March and everything was fine. The spa started fine, the heater worked,
    but when i turned both off the "cool down" cycle did not stop. Jets kept spewing air. I finally manually stopped pump. After an hour or so, I started just
    the pump, which worked, but water was being drained from Spa into the pool. It stopped everything, but am wondering what might be causing that.
    The filter was cleaned just recently by my MTC company, and I am wondering whether they moved any of the levers?? Any insights would be welcome.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Pump not shutting down after testing SPA
    Can you give us a list of your equipment as it is described here: Pool School - Read This BEFORE You Post
    Mark
