Thread: Pool math
    Jun 2016
    Israel
    23
    Pool math
    Can anyone explain how to use the pool math calculator
    New pool. Here are my reading \
    ppm 0
    ph 8.4
    ppm total alkalinty 240
    SummerEscape Vinyl round. 366x122m
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Pool math
    Do you have any other numbers that does not tell us much other than your pH is likely dangerously high and needs to be lowered with acid.
    Jun 2016
    Israel
    23
    Re: Pool math
    I only have a strip test and it tests for
    free cholrine
    ph
    ppm total alkalinity.
    So for PH I would need to use add -ph solution.
    Jun 2016
    Marengo/IL
    48
    Re: Pool math
    I'm a new pool owner and have an important suggestion. Please consider purchasing a test kit. TK-100 is the one I bought. A little expense up front but you'll know your exact numbers. The website to purchase test kits is in the forum somewhere. I'll find it and follow up.
    My TA is high also but by other's suggestions I am being patient as changes in pool water can take days to balance out in some cases.
    TerriP
    27'x54" AGP - 2HP Hayward SWIMPRO LX PUMP - SW150 Hayward SWIMPRO Voyager Element Tank- - Dyna-Skim Wide Mouth Skimmer SP1091WM - Aquaray vaccuum
    ckk81's Avatar
    Jan 2015
    Kalamazoo MI
    233
    Re: Pool math
    Quote Originally Posted by TerriP View Post
    Sent from my iPad using Tapatalk
    Yep- you NEED a proper test kit. You'll save money and headache in the long run. Test strips are generally worthless.
    30K? gal (20x40, 3ft shallow to 8-9ft hopper), Vinyl IG, single speed 1HP pump, Hayward Micro Clear DE-3600 filter, Hayward Aqua Rite SWG T15 Cell, Rheem/Raypack M206A heater
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: Pool math
    Here is how to use Poolmath
    Pool School - PoolMath
