Thread: Calcuim question - SWG
    Jun 2011
    Shelbyville, Indiana
    11
    I am converting my BBB chlorine pool to a Salt water pool and have a question concerning my calcium level reading.
    All of my numbers are in line for a SWG pool except the TA which I am bring down by aerating and am currently at 130 heading to 60-80, but using the poolmath app i am getting CSI readings that indicate I am out of balance.
    My current CH reading is 160. Should I add some calcium chloride to get the number above 200 or leave it as is.
    I have a vinyl liner.
    As always, appreciate any assistance.
    Monty1
    Vinyl Liner-24K-2 skimmers-bottom drain
    Sta-Rite sand filter
    Sta-Rite 1HP Pump
    Circupool RJ-45 SWG
    TF100 Test Kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Calcuim question - SWG
    What is the number? You want your CSI to be negative, it doesn't really matter what the number is in a vinyl pool since you have no plaster to etch. CH at 160 is fine.
