Results 1 to 8 of 8
Thread: Chlorine Drop Test - Quick Question
    mickey4paws's Avatar
    Apr 2009
    S.E. MI
    570
    When adding the powder, it says to swirl and then the water should be pink in the test tube. Does it turn pink right away, or should it sit for a few minutes? Thanks
    IG 12' x 39' - 20k Gallons - Vinyl Lined - StaRite Cristal-Flo II 26" Sand Filter - Hayward SuperPump 1 hp - Dolphin Dynamic autocleaner - Lochinvar Energyrite gas heater - Aqua Rite SWCG T-15 - TF100 Test Kit - Skimlite Duallly 9016 pole (great pole)
    Re: Chlorine Drop Test - Quick Question
    It should turn pink right away. If it doesn't then either there is no chlorine, or there is a really really large amount of chlorine. I try one more scoop, and if that still doesn't do it, confirm with the OTO test. If the OTO test (blue box in the FT100, drops turn the sample yellow which is compared against a color standard) stays clear then there really isn't any chlorine.
    Apr 2009
    Sarasota Florida
    143
    Quote Originally Posted by mickey4paws
    should turn pretty quick, if it doesn't add another, if it still doesn't after several you may have no chlorine in the pool.
    Kidney shaped ~ 10000 gallon Ig Plaster pool with pool cage. 120sf Cartridge filter. Pentair WhisperFlo WFDS-26, 230 Volt, 7.8/3.0 Amp, 1-1/2 Horsepower 2 speed pump, Solar panels on the roof. Heliotrope HelioMatic 4000D solar controller.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    that swirling thing is really a pain to me. it's either too slow or I splash out. when I got an eye dropper to get my test tubes to the exact amount of required water, I found out it was also an excellent stirrer.
    Apr 2009
    S.E. MI
    570
    Thanks everyone! It did turn pink right away but took a while to clear. It's supposed to be completely clear, and not just very, very light pink, right? Argh, I am so not good at chemical things
    Apr 2009
    Sarasota Florida
    143
    not clear but colorless. No pink
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Make sure you are using the little scoop end and not the flat end.
    If you are doing it correctly and it takes many drops that means your FC is very high. How many drops did it take?
    Guest
    Quote Originally Posted by reebok
    Stirring with an eyedropper is not the same as swirling and you could contaminate the different tests if you use the same dropper for each. Get yourself a magnetic stirrer. One of our members sells one and it's worth every penny!
    portable-magnetic-stirrer-from-apollo-pools-t1489.html
