Results 1 to 13 of 13
Thread: Help need DIVING not N0-Diving sign
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I need help locating a replacement safe diving sign as my old one is getting brittle and cracks if touched.
    Here is my old one, I would like to find another copy of it or similar
    I bought it off ebay several years ago and there are no markings to suggest who made it.
    thanks Ike
    cubbienate's Avatar
    May 2016
    Hampshire, IL
    87
    Re: Help need DIVING not N0-Diving sign
    You might be able to take that to Fedex / Kinkos or Staples and see if they can scan it and print it on vinyl sticker or some type of sign materiel. They can reproduce that. Or try a sign shop. They can scan that and print you something real quick I am sure. If you get a good scan I can ask my friend that does signs if you strike out locally.
    15'x24'x52" Saltwater 5000 Oval AGP, Hayward S180 Sand Filter / 1.5 HP Power Flo Pump, Hayward AquaTrol Chlorinator, TF-100 + Taylor K-1766
    twinkiesmommy2009's Avatar
    Aug 2015
    Cypress
    1,679
    Quote Originally Posted by Isaac-1 View Post
    thanks Ike
    I use an app on my phone called TurboScan. It does a good job and then you'd have the image to order an exact copy. Could even go the cheap route and just print and laminate if you wanted.
    Started 5/31/16. 38'x23', 618 sqft., <14,000 gallons, 8' spa.Travertine coping. Raised beam w/3 sheers. Large sunshelf w/3 bubblers. SWG IC40, Pentair VSP, 520 cartridge, color LED lights, Easy-touch, screen logic, Maytronics S300i robot, and Wet Edge Prism Matrix finish (Deep Sea Blue with Indigo plaster). Build Thread: Another in Texas - Cypress Texas | MUD District | HOA Approval | Great Escapes Pools
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I doubt if a copy will work, it is hard to tell in the photo, but the quality of the original is not all that great with a number of rounded off letters, and small spaces like the centers of eee's filling in.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,318
    When my new liner was installed last fall it included one of those which I put on my fence.
    Can you contact your liner mfg to get another one?
    Dolphin E10 Cleaning Robot.
    cubbienate's Avatar
    May 2016
    Hampshire, IL
    87
    Found this one online not exact but close.
    Warning Sign
    Or that really little print might have a number on it that you can Google. Most signs have a part number of them that they change when they update wording. (Well I know from other safety signs not pool signs)
    Isaac-1's Avatar
    SW Louisiana
    6,711
    I am not sure what brand the liner is, but it is 12+ years old and the installer has went out of business
    38,262
    Quote Originally Posted by borjis View Post
    What liner MFG? Maybe they have them available?
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,318
    Plastimayd
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Thanks I will check in with them when I get back from vacation, also the small print at the bottom is not helpful, it just says to not paint over the sign.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,468
    LOL! That's a handy tip!
    RyanMcC's Avatar
    Aug 2013
    NH
    214
    Wow, the safety people are out of control!
    This is the only "be safe" sign I could find on Google:
    "...chemistry is not an exact science" -Mario Andrada, Rio 2016 Olympics spokesman
    21' x 52" Radiant Metric Round ~10K gal AGP with Hayward S180t pump/sand filter.
    Caldera (Watkins) Martinique 340 gallon installed in basement, Bromine and ozone.
    Taylor K-2006 test kit.
    Jul 2015
    Central Valley CA
    1,107
    found THIS in google images copyright aside I bet you could use the image and either keep the text or put it into a picture editor and put your own text in. Then go the Kinkos route.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
