Hi guys, New to the site and would appreciate any input. About 2 months ago I expanded my screened room and had my pool resurfaced and pool deck redone. They first resurfaced the pool and filled it back up with water. The pooldeck guy then came in and sprayed a mix of sand and epoxy then flattened it for the texturing before staining the overlay.
The sand epoxy mix was sprayed into the pool... A lot of it and I was told it was normal and would vacuum right out. I vacuumed a lot over the next few weeks and constantly cleaned the filter and even replaced the filter cause it got to gummed up. The sand still stuck to the sides and floor, two months later there are still streaks of the sand that adhered to the floor, I got it off the sides for the most part but took serious elbow grease. Without scuba tanks I can't do the same to the bottom. Is there a product that will loosen this stuff? and was it normal to shoot all that into the pool?
Can I try to pressure washing it or will it damage the aggregate finish?[FONT=Helvetica Neue, Helvetica, Arial, sans-serif]
[/FONT]Thanks for any information I appreciate it.
Tim
Tim
