Thread: Replacement Motor
    Jun 2016
    Chalmette
    1
    Replacement Motor
    I have a Waterway part number 7-177781-2. Is there an alternative motor I can use. I opened the back up and the coil inside is black. Looks burnt. It turns with a screwdriver. But when you turn it on its jammed.
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Replacement Motor
    Post the following information that is on the motor label:
    HP
    SF or Service factor
    Frame
    Or just post a picture of the label.
    Mark
