Thread: solar cover spins
    careingemt's Avatar
    Sep 2013
    PA
    143
    solar cover spins
    Hello,
    I'm having trouble with my solar cover spinning.. Any ideas how to keep it from spinning.. I'm using the eyeball for my return. Should i try a elbow then the return. I'm using a ladderwhich should hold it or do i need to cut the cover so it lies flat inbetween the ladder legs?
    Thanks for any idea's
    Fran
    AG 18 feet accross 52" high pool wall 7000 gallons .... pool math = 7600
    Hayward extreme cartridge filter 100sq feet
    pool is heated by propane Hayward heater
    pool installed aug 12 2013
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: solar cover spins
    It is generally best to cut the cover to lie flat on the water so that the wind doesn't pick it up. I've never heard of one spinning from the water rotation. Kinda funny!
    careingemt's Avatar
    Sep 2013
    PA
    143
    I was not trying to be funny ...Should I take a picture of my bunched up cover.. mabye I didn't explain well
    DFW, TX
    24,450
    I was picturing the cover spinning on top of the water, wheel of fortune style. Bunching up is probably more from the cover sticking up and catching the wind. I would cut the liner so that it lies flat on the water to see if that fixes it. Seems like it will.
    careingemt's Avatar
    Sep 2013
    PA
    143
    Tonight I'll cut the cover .. hope that works. By the way ...if I take out my ladder so the cover lies flat the water current will have it spinning in no time. I dont think it's from the wind....
    Jamison04's Avatar
    Jun 2011
    Tecumseh, OK
    573
    I don't think the spinning is really an issue. If you cut slots for the ladder than you have to make sure you get it on the same way each time which could prove to be a pain. It's probably best to just pull the ladder and just let it do its thing. If it's cut to the proper diameter of the pool than it should just lay on the water. Only thing I could foresee would be as it spins it might catch water and it'd get on top of the cover.
    24'x52" Artesian w/ Portifino liner - Hayward 1hp powerflo matrix w/24" sand filter - AquaTrol RJ SWG. Solar heating to come. -
