Thread: Another very satisfied TFP customer
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,778
    I found this site while looking for info before building my pool and have found the answers to questions before I even knew I had to ask them. The people here are very helpful and patient. The information is backed by solid science and real world knowledge. I'm still working on the decks and remaining site work around my pool that went up a month ago, but the clarity of the water and ease of maintaining the pool with the TFP method is shocking. After the initial fill of the pool I added borax, cya, liquid choline, and baking soda to the pool to target levels. Since then the only thing I've had to do is add about 3 cups of bleach even other day to keep FC above 3. I didn't know water could get so clear and if I wasn't the one putting chlorine in the water I would swear it wasn't there. You can go under water and look down the length of the pool and see the screw heads in the skimmer 30ft away. From the second story windows in the house you can see the sinker toysat the bottom of pool like they were sitting on the deck.
    I wanted to write this as a big thank you too all the people on this site who take the time to share their knowledge with the world.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Re: Another very satisfied TFP customer
    Thank you for your kind words and your financial support as well. It is our members that make TFP the great online resource that it is.
    Love TFP? Become a
    TFP Supporter!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Nice pool! Thanks for supporting TFP!
    Ncdamsel's Avatar
    Jul 2015
    Garner ,NC
    65
    Pretty pool!!!
    13,995 gallons 24 X 52 / above ground pool.../.SWG/ sand filter/ vinyl liner
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    that is come clear TFP water there, and a nice deck coming along
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,778
    Thanks the deck has some growing to do. Next step is an upper acess deck between the pool and the hill with stairs to the lower deck. The pool ladder for now is temporary until all the wood work is done.
    Chuck-
