Thread: Hayward slide valve open by itself?
    Jun 2016
    New Jersey
    3
    I have a crazy question. I have a hayward slide valve attached to a Hayward DE filter. For the last few years I have been unable to rotate the handle to set the locking pins in place. It never seemed to be a problem as in no water leaked through the backwash hose when in down filtering position. The filter turned on this morning and when I came back a few hours later I noticed the pool water level had dropped 6 inches. When I went to look at the the filter I immediately saw that the push-pull valve was in the up position and water was streaming out the backwash hose. My question is can this have happened from water pressure or did somebody deliberately pull up the valve to start emptying the pool? I would appreciate any feedback on this. Thanks
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Hayward slide valve open by itself?
    Welcome to TFP
    I have not heard of a valve moving by itself, maybe someone moved it not knowing what it was...
