Results 1 to 12 of 12
Thread: New patio now ladder not lining up
    Hello
    We had our pool put in last year and just now had our paver patio installed. The company doing the pavers agreed to re seat the ladder anchors because they were set too low. Today I went to install the ladder and found that one anchor is 18.5 " from lip of coping and the other side is 19.25" from lip of coping. This causes the ladder to only come in contact with the pool wall on one side. I think both sides need to be further back from coping as the ladder will only come in contact with the wall if stepped on.
    Is there certain measurements or guides for most standard ladders or is each manufacturer different, I would appreciate any help before these guys come back to correct it
    Thanks
    Tom
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: New patio now ladder not lining up
    Someone who knows for sure about it will chime in soon but in the mean time is it possible to post a picture of the trouble. I would think that the people who installed the pavers should come back and make it right.
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Sep 2007
    Guelph, Ontario, Canada
    60
    When the ladder was initially assembled to the position of the anchors. The alignment is maintained by the screws securing the rungs tot the vertical rails of the ladder.
    If your anchors were repositioned, it may be as simple as loosening all the screws about 3 turns, and placing the ladder into anchors. See if you can realign by moving the ladder side to side until the bottom rests nicely against the pool wall at both points. If you can, get in to the water, and retighten the bolts.
    Carl Schnurr
    Pool: 96,000 litre, vinyl liner, 1 HP pump, sand filter, Aqua-rite SWG, Hayward e.vac, installed 2005
    Spa: La-Z-Boy 'Relieve', 1300 litre, acrylic, with ozonator, installed 2017
    Test Kit: Taylor 2005C
    Thank you Carl
    I will try what you mentioned. The fact that one side is 3/4 of an inch further back then the other (receiver) may be OK?
    Tom
    Sep 2007
    60
    I just went and measured mine. One anchor is 14, the other is 14.5".
    I would only be concerned if you can't realign.
    Carl Schnurr
    Ok I loosened the rungs and was able to pretty much straighten it out so both bottom rung bumpers meet evenly towards the wall. BUT they are sitting about 1 -2 inches from wall. Can I try to bend it in (out of the pool) or will using it make it sit better
    Ps I still need to go in the pool to re tighten everything
    Would you like a picture of it??
    Thank you for your help. As I said before this is a great site
    Tom
    I also found that the receivers are not truly vertical. I put a level on the ladder rails and found it is pitched away from the pool.
    Maybe with use it will sit better
    Tom
    phenwick's Avatar
    May 2009
    Metro St. louis Mo.
    11
    My bumpers have never rested completely on the pool wall, until a swimmer puts their weight on it ti climb out. Never seemed to be an issue to me. Getting the top rung level with the surface has been the only adjustments I make.
    Dave
    22,000 IG vinyl; Swim Out; Sand Filter
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    mine also sit away from wall. I don't think they are supposed to rest on the wall unless someone is on it.
    Ok I guess it is the best it is going to be then. The rung adjustments did help so I'll leave it.
    Thanks so much guys and enjoy the holiday
    Tom
    Mar 2007
    Coastalish 'down easter'
    4,160
    Tom, they were not properly installed! A lot of deck guys have problems with this
    If you plan to keep it as it is, make sure the bumpers can't come out of the bottom!! you're liner is at a VERY large risk of being punctured if they do!
    An easy way to insure proper installation is to set the anchors with sac-crete before the deck gets poured - you can use a couple of metal coat hangers to tie the cold pour into the new crete (honestly, a brain dammaged monkey could figure this out... but not the pool deck experts )
    I think you're best off having them reset the anchors!
    Luv& Luk
    -Ted
    I thought of that also. The bumpers come out quite easily also
    Tom
