Thread: Another newbee starting 1000 gal. Pool
    Jul 2015
    Sudbury ontario
    2
    Hi
    trying to get my reading correct
    i cover my pool with styrofoam sheets, insulated the walls and have this little guy on styrofoamed pad under sand to help keep the temp more level.
    My question is how do I get the chemistry balanced?
    fc 10
    cc 10
    ph 6.8
    ta 40
    ch 0
    cya 0
    temp 28 C 82 F
    its a little cloudy
    thanks for your consideration in advance
    cheers
    Mike
    above ground vinyl soft sided pool with a sand filter 1.5hp Hayward pump (don't laugh)
    10 foot dia. 30 inch deep
    the volume of water would seem to be closer to 9 feet x 2 feet, 950 U. S. Gal.
    Jun 2012
    western NY
    1,562
    Re: Another newbee starting 1000 gal. Pool
    there is a great app in the pool school section that you can enter your current #'s into and your target #'s. It will then tell you what and how much to add.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jul 2014
    Oakbank, Canada
    389
    http://www.troublefreepool.com/calc.html Here is the link they are talking about.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    What test kit are you using?
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
