Thread: Still getting algae
    Jul 2015
    Riverview, mi
    24
    Still getting algae
    I'm still kind of new to this site. Every year I seem to get some green around the edge of the pool. Or I get some dirt spots and when I vacuum them, I notice some green underneath them. I just tested...
    FC 18
    CC 0
    Cya 80
    How am I getting algae when my chlorine is that high?! The filter is running 8 hours a day, although it hasn't been used much for a few days.
    Jun 2016
    Martinez, CA
    207
    Re: Still getting algae
    With CYA at 80, you need 30ppm to shock it effectively
    18,000 gunite pool/spa combo. Pebble tec, iaqualink rs8, cl580 filter, aquapure 1400, 400k btu lx heater, 10 solar panels, jandy 1hp, 1 1/2hp, and 2hp stealth pumps for circ, spa, waterfall
    Jul 2015
    Riverview, mi
    24
    Thanks. How did algae even start keeping it so high? What's the lowest I should go for maintenance?
    Jun 2016
    Martinez, CA
    207
    Use the cya/chlorine chart that is on the website. It includes min FC, and levels to shock based on CYA concentration.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Good advice!
    Here is the FC/CYA Chart
    And here is how to SLAM
