Thread: SWG/bleach
    Jun 2013
    Bel Air Maryland
    21
    SWG/bleach
    I have a SWG now and wondering if there are any negatives of converting to chlorine.
    30,000 gals./ In ground/Vinyl liner/Cartridge filter/A.O Smith 1 1/2 HP Pump/Pool Installed in 2008/Tf-100 test kit just ordered/Aqua-Rite SWG/well water
    Jun 2014
    15,056
    Re: SWG/bleach
    FC generated from a SWG and FC added from bleach are basically the same thing. SWGs simply use salt in a conversion process to make the FC, therefore you have some salt content in the water at all times that's all. The biggest complaint about adding bleach to a pool is typically carrying a jug out to the pool each day. With manual additions, you no longer have to check salt content in the water, just test FC each day. You can also have a slightly lower CYA level with manual chlorine.
