Thread: Need to SLAM and have a CYA question
    Jun 2012
    Springtown, TX
    54
    Hi all,
    I'm 2 hours new to all this, so forgive my ignorance.
    We have dark green algae and need to SLAM. I'm ordering the test kit.
    So, currently our CYA level is 10. I noticed on the chlorine/CYA chart that 10 isn't on the chart. So, should I increase the CYA before SLAMing?
    Jun 2014
    15,237
    Re: Need to SLAM and have a CYA question
    Yes, ideally 30 is a good starting point as it doesn't require as much bleach as higher CYAs but will also provide some protection form the sun. 30 is good.
    To increase CYA via granular stabilizer, place the required amount as calculated by the Poolmath calculator into a white sock and place in the poolside skimmer basket. For those concerned about suction flow to the pump, suspending the sock near a return jet or from a floating device will also suffice. Best never to allow undissolved granules to rest directly against the pool surface. Squeeze the sock periodically to help it dissipate. Once dissolved, consider your CYA adjusted to that programmed (target) level. CYA test readings should show a rise in 24-48 hours, however some pools may experience a longer delay to fully register. Best to confirm final CYA in about 5-7 days before adding any more stabilizer/conditioner.
    Jun 2012
    Springtown, TX
    54
    Thank you!
