Results 1 to 7 of 7
Thread: Waterfall Ideas for Above ground pool with deck
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    I am looking for an inexpensive way to create a waterfall for my above ground pool. I have a deck and I am considering putting it on there. Suggestions.....and go.
    24 ft. round ABG-vinyl-15200 gallon
    Sand Filter w/1 1/2 HP pump
    Installed May 2011
    Taylor K-2006 test kit
    BBB method
    http://www.poolcalculator.com/
    pool-school/chlorine_cya_chart_shock
    pool-school/shocking_your_pool
    pool-school/pool_test_kit_comparison
    Jan 2010
    Randleman,NC
    620
    Re: Waterfall Ideas for Above ground pool with deck
    Only thing waterfalls do is up your PH.
    Leasure bay AG 24ft,52 in high.installed June of 1999. Hayworth S-180 T sand filter/Power-Flo Matrix 1horse 2 speed pump /Aqua Trol SWG/Using TF-100 Test Kit
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    You could adapt a pond waterfall to use it with the pool. Here is a link to an old thread where someone did the same thing. waterfall - Page 2
    Love TFP? Become a
    TFP Supporter!
    Jul 2014
    Oakbank, Canada
    389
    Quote Originally Posted by poolmama67 View Post
    Sounds like a great idea. Plumb a line into the inlet hose to a T fitting, with PVC pipe with slits cut into it. Cap the ends, allows the water to flow up and into the pipe, and out the slits. Use it with a diverter valve and you can regulate how much flow from the inlet union.
    Ultra 16', Intex Sand filter/pump combo, 8' x 20' solar panels, solar blanket w/roll tube, 1" extruded foam floor with Gorilla pad, Liquid chlorine and stabilizer.
    poolmama67's Avatar
    May 2012
    Arkansas
    209
    Quote Originally Posted by kplaster View Post
    Sent from my XT1030 using Tapatalk
    Yeah but I love the sound and my husband loves the feel.
    Installed May 2011
    BBB method
    kk_isme's Avatar
    Aug 2015
    North Central Texas
    108
    I'm looking to create a water feature for my agp, too. It really helps keep the water temperature cooler. It was 90F tonight. And not even July, yet. Ugh.
    14,000 gallon above ground 24ftx56in round vinyl overlap liner steel wall sand filter 1/2 hp pump heavy lime in city water morning shade
    Jan 2012
    'burbs of Augusta, Georgia
    7,368
    Check out Skippy's Cooling Fountain (link in my siggy line) It would be pretty easy to add to an AGP. It sounds nice and cools water down well.
    Ooops- never mind.. I didn't realize you meant a jungle type fake rock waterfall. I was thinking "fountain". sorry!
