Thread: Aquacomfort heat pump cycling on and off.
    Jun 2016
    Farmingville
    1
    I have a 6 year old aquacomfort ac1500h that cycles on and off. There is no code on the screen when this happens. When on it blows cold air out the fan. Only runs for about 5 minutes. I would mention that there is no temperature reading on the screen also. Not sure if that makes a difference.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Re: Aquacomfort heat pump cycling on and off.
    Sounds like a refrigerant, compressor or expansion valve issue. Call your favorite hvac company to check it out. Pool heat pumps should be serviced regularly just like home hvac systems. You can even add it to your service contract if you have one.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,770
    I second that it sounds like symptoms of low refrigerant or a sticking txp valve.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    I just so happen to also have an Aquacomfort Ac125 and my TXP valve is working but sticking causing an HP error. Surprised at the $850.00 price I received to repair. It does have to be evacuated and new valve sweat in and then recharged which takes time.
    What do you all think about that price?
    Thanks Much
