Thread: Intex filter Pump not suctioning
    Jun 2016
    Meridian, Mississippi
    5
    Good morning! I have an Intex Ultra Frame swimming pool and it does not suction. The pump comes on and I can feel the water running through the hoses....it just doesn't seem to be suctioning. Has anyone else had this problem?
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Re: Intex filter Pump not suctioning
    It would be helpful to know what Intex pump you have. The answer will depend entirely on this info.
    Jun 2016
    5
    Sorry about that. Its a Krystal Clear Model 633T Filter pump.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    If you mean there is good water flow from the outlet (pool return) but you cannot feel suction from the dual inlets (suction side) then it is working as designed. The system is designed not to be able to feel suction at the inlet to eliminate risk of people, especially small children, from becoming trapped against the pool wall.
    Jun 2016
    5
    That is exactly what I meant and thank you so much! I thought you were supposed to feel a little suction. The filter is dirty so I know that it was working, but I guess it was just slow for me. Thanks again!
