Results 1 to 9 of 9
Thread: Inground Pool - Lights Not Working
    We built out pool in the summer of 2010.
    We had two lights (non-LED) installed in the pool.
    Over the last few years we haven't really used the lights because our kids were so young and typically when it got dark we were putting kids to bed and cleaning up. Night swimming never really happened.
    Now the kids are older and our backyard has turned into the neighborhood hot spot we are using the pool at night.
    I haven't used the lights yet this week, but last night I tried to turn the lights on and no luck. The breaker for the lights are on, and I turned the switch on, but DARKNESS.
    Can someone help me troubleshoot my lights?
    Is this as easy as getting new bulbs?
    Is this a DIY job, I would rather not have to call in a "professional" if I don't have to.
    76549 Liters -- Cartridge Filter -- In Ground -- Vinyl -- TF-100 Test Kit -- AquaVac Robotic Cleaner -- UV Sanitation -- Winter Safety Cover -- Installed 2010 -- Southwestern Ontario, Canada
    Latest Test Results June 25:
    FC - 6, CC - 0, CYA - 40, CH - 110, TA - 90, pH - 7.5
    Aug 2008
    Fredericksburg, VA
    51
    Re: Inground Pool - Lights Not Working
    Since that involves dropping the water level below the level of the lights, I'd just wait until you close your pool for the season. We only occasionally use ours and if I had to go the rest of the season without it, it wouldn't kill me. But my guess is that it shouldn't be a big deal to replace yourself.
    20,000 gal. free-form plaster on concrete
    Triton DE filter, 1.5HP pump
    Aquabot Elite pool cleaner
    Jun 2015
    Central, NJ
    566
    It is not too hard to do yourself, there is a video on inyopool.com under the light bulb section. You do not need to drain your pool but a mask and snorkel help and a scuba tank makes it very easy. The bigger problem is parts if equipment is old, but 2010 is not old. I want to put LED light in but my fixture is too small to accommodate and my niche will not accommodate a fixture that does allow an LED. If you can't find video, post and I will find and link it for you.
    27,000 gals (20 x 40), IG, vinyl, Hayward Sand Filter S244T 300LB, Hayward
    Super pump SP 2607X10 1 hp.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,478
    Most pool lights are on the end of a long cable that allows the light enclosure to be removed and placed on the pool deck. There should be no reason to drain your pool.
    But.. both lights are not working and they have been very lightly used.. Off-hand I'd suspect the power going to the light, before suspecting that both light bulbs are bad. This power should come from a GFCI circuit breaker, or a GFCI outlet. The very first thing I would do is to make sure that you have power going to the lights.
    Aug 2008
    Fredericksburg, VA
    51
    Weird. I just assumed you'd have to lower the water below the light, but I guess that would be pretty crappy design.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    No need to drain wather. Depending on the model 12V or 120V lights you may have a circuit breaker/fuse on the power supply for the light. It seems odd that both lights wouldn't work. I would believe voltage/electrical issue.
    Do you know the model of your pool light?
    Here's a video showing how it's done: How to Replace a Pool Light Bulb (Lamp) - YouTube
    Ok, so I have a GFCI outlet. I pressed RESET and TEST a bunch of times and all of a sudden now it works.
    I wonder if one of the buttons on the GFCI were stuck.
    Jun 2012
    western NY
    1,559
    Quote Originally Posted by Easto View Post
    Which did you press first???? GFCI's are designed to not fail in the on position. This is not to say it can't happen. I would guess that the reset was pressed first as it probably was tripped. As to why it was tripped, ...anybody's guess.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Apr 2011
    Murrieta, CA
    2,360
    Great news!
