Thread: New to forum, need lots of help
    Sewingmom's Avatar
    Jun 2016
    Woodville/Alabama
    6
    Hi folks, Thanks or the welcome, I am so glad I found Y'all. I am 67 years young and,
    Because of my husbands disability I am forced to learn pool maintenance. Our ABG pool is 12 years old (25 year predicted life span), I am just learning the opening up procedures. Ronnie had a brain hemorrhage 3.5 years ago. My son has opened the pool and maintained it the last 2 years but no longer has time to deal with it and last year one sensitive skinned grand child, actually had a chemical burn from swimming in it. I have just discovered the BBB method of maintenance so am switching to it.
    I need to get on with using the pool, it is my only relief from caregiving and working.
    sewingmom
    sewingmom
    chlorine system, sand filter, Hayward pump, 24" round abg, BBB method
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Re: New to forum, need lots of help
    Ok, time for some Pool School.
    Start here
    ABCs of Pool Water Chemistry
    Then here
    TFPC for Beginners
    Come back with your questions
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    pooldv gave you some good resources - I highly recommend them.
