Results 1 to 17 of 17
Thread: Pump Tripping Circuit Breaker
    Jun 2016
    Holmdel, NJ
    6
    I just bought a Hayward SP2615X20 Super Pump 2 HP inground pool pump from Amazon. Initially, I configured it to 115V because I did not realize that I had a separate power supply for the pool. Of course, that didn't work out so I switched the configuration back to 230V. I'm pretty sure the wiring of the motor is done correctly.
    Now, when I try to turn the pump on, it will only run for 2-3 seconds before it shuts down and trips the breaker. The motor runs and the vacuum works but only for a couple seconds.
    The breaker is a GFCI 40 Amp circuit breaker. With a start capacitator in the pump, I don't think it should be drawing so much current that it trips the breaker.
    Could there be any damage to the wiring or the pump after the I used the wrong configuration?
    Thanks for any help.
    CJadamec's Avatar
    Apr 2016
    Quaker Hill, CT
    1,766
    Re: Pump Tripping Circuit Breaker
    Yes if you wired the wrong voltage to the motor and ran it you may have damaged the windings in the motor. You may have also blown out the capacitor.
    Chuck-
    15x30 AG, Pentair Superflo VS, 19" sand filter, TF-100 test kit
    Aqua Comfort ACT750 heat pump / 6x20 ground mount solar panel / DIY automation
    Photos of 2016 Build, Inside Your Breaker Panel, Free Copy of 2017 NEC code
    TFP is AD Free and is funded solely by member support click here to help
    Jun 2016
    Holmdel, NJ
    6
    Would this cause the motor to run for a few seconds and then stop? Because that is what is happening right now. I would think that if the windings in the motor/capacitor blown out, it would not run at all.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Welcome to TFP!
    Quote Originally Posted by lauralindy
    If you are just "pretty sure", I would have it checked out by a licensed electrician.
    The good news is that it is unlikely that the source wiring was damaged - the circuit breaker's primary job is to protect the wiring from overload. You also could have a ground-fault issue somewhere. If it is not correctly wired for 230V, it may be reading the neutral return as a ground fault given that the breaker is a 230V GFCI. Also, keep in mind that if the motor is wired for 115V, it will pull twice the amps vs. correctly wiring it for 230V.
    Bottom line: If the breaker trips within a few seconds of operation, it is a sign that it is not wired properly. I would definitely have it checked out by an electrician.
    Jun 2016
    Holmdel, NJ
    6
    Quote Originally Posted by BoDarville View Post
    Welcome to TFP!
    Are you talking about the motor voltage configuration wiring or the rest of the pool setup wiring specifically?
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    If you are asking about what I meant by "the source wiring", I was referring to the wiring from the breaker to the motor. If you are still able to get the pump to start up again (which it sounds like you did), that's a good indicator that the pump motor is OK, but I wouldn't press it or you risk damaging it. Please have the wiring checked out by a licensed electrician - it may save you the cost of a new pump motor as well as other collateral damage.
    Jun 2016
    Holmdel, NJ
    6
    I'm an electrical engineer which is why I thought the wiring was ok.
    I want to measure the current myself but my ammeter is only a 10A one. It's certainly drawing in way more current than that to be able to trip my 40A breaker.
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Electrical engineer does not equate to licensed electrician. There are wiring diagrams that must be followed. You wired something incorrectly. I'd recommend professional help at this point. It would be awful to be injured/killed just to save a few bucks.
    May 2009
    Youngsville NC
    395
    My 1.5 HP pump is on a 20 AMP GFCI breaker with minimum 12 GA wire out to the pump. The plate on the motor states that max power draw on 240V is about 7.5 - 7.8 Amps, and I'm usually pulling 5-5.5 amps , so I can't imagine your 2HP taking much more than 10-12 amps on 240V.
    I'd start by making sure that you ARE supplying 240V, then checking your wire size out to the pump. For a 240V pump, 12 ga should be plenty (figure extra if you are running other items as well. I'd also like to know what the wiring between breaker and pump (things like switches and timers as well). Are you running 120V stuff off of the pump circuit without a neutral wire ?
    I'd also like to know pool size and why it was recommended that you get a 2HP pump - seems pretty darn big to me.
    And if all else fails - time to get an electrician out there.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    Mar 2015
    Cantonment, FL (Pensacola Area)
    380
    A 40A breaker? That would be 8 Gauge wire I think, you really using wire that heavy to the pump?
    Scott
    15,000 Gallons vinyl in-ground screen enclosed, Hayward Eco-star SP3400VSP, Hayward Aqua Logic PL-Plus, Hayward T-15 Salt Cell, Hayward S244T Sand Filter, Polaris 380 with booster pump, Hayward heat pump HP50HA. K-2006 kit.
    Apr 2011
    Murrieta, CA
    2,360
    Here's the link to the manual: https://www.hayward-pool.com/pdf/manuals/SuperPump.pdf
    WARNING – All wiring must be done by a licensed electrician and must conform to all
    local and national codes and regulations.
    WARNING – Ground and bond motor before connecting to electrical power supply. Failure
    to ground and bond pump motor can cause serious or fatal electrical shock hazard.
    WARNING – Do NOT ground to a gas supply line.
    WARNING – To avoid dangerous or fatal electrical shock, turn OFF power to motor before
    working on electrical connections.
    WARNING – Ground Fault Circuit Interrupter (GFCI) tripping indicates electrical problem. If GFCI trips and
    won’t reset, consult electrician to inspect and repair electrical system.
    WARNING – Fire Hazard. Match supply voltage to motor nameplate voltage.
    Check Page 6. 2hp 230V motor calls for a 15 Amp breaker. Not 40 amps.
    These directions show how to replace the motor, but cover the wiring directions. It may help with your trouble shooting: How To Replace the Motor on Your Pool Pump - INYOPools.com
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Quote Originally Posted by bobodaclown View Post
    newbury2000's Avatar
    Jun 2016
    Phoenix, az
    15
    Big difference in 115v to 240v is that the 115v uses a neutral and the 240, actually 220 does not use a neutral. Sounds like your wiring in the pump is incorrect and causing the gfci to trip.
    38K gallon in ground pool. Painted with an epoxy paint (Pool Guard EHB). Painted over a plaster/fiberglass mix. Triton 2 sand filter with a 1.5 hp motor. suction side cleaner, generic style kreepy crawler style.
    Up to date I have been taken to the cleaners with pool store chemicals. New to this form of pool care. (and excited about it)
    Jul 2013
    Western New York
    3
    If the pump runs a few seconds, sounds like the wiring to the the pump could be a problem. it is most likely not drawing too much amperage, but something is causing too much resistance. could be something is making a connection to ground, hince it is tripping.
    Jul 2013
    Western New York
    3
    Quote Originally Posted by NeedMoreSun View Post
    Yes a 40 A breaker does require 8AWG to carry that.
    Jul 2013
    Western New York
    3
    Looking at the owners manual online for that pump indicates that wired for 115 V you would use a 30A breaker with 10AWG wire. wired for 230V you would be using a 15A breaker with 14AWG . So wired for 230V a 40A breaker is too big. It would not trip soon enough to prevent damage not only to the pump, but also to your panel etc. While 8AWG is more than is needed, it is not your problem. Good luck.
    Jun 2012
    western NY
    1,559
    How about posting a picture of the wiring connections inside the motor junction box so we can see what is going on.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
