Thread: Circulation/ return help AGP
    Jun 2010
    Central Indiana
    92
    I have a 24' round agp with 1hp hayward pump and a Hayward sand filter. I cannot get sufficient circulation throughout the whole pool. The side opposite the direction the eyeball points always ends up with standing dirt on the floor and filthy walls. The side the eye points stays clean. I've tried down and left, down and right, and down with straight across. I've tried varying degrees of down as well and always seem to have dead spots. Amy thoughts on how to resolve this? Should I look and a specialty eye such as "the circulator" or is there a magic direction for my eye I can't find?
    13500 gallon AG (24' round), 100 sf cartridge filter, Hayward 1hp pump, pool 10-15 years old with recently replaced liner
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Circulation/ return help AGP
    Do you only have 1 return (eye)? If so, thats likely your biggest problem. One return on a 24 ft pool seems to me to be not enough. I would think at least 3 spaced equally apart so you can get some good circulation would be about right. If you're handy, it's not that difficult to add additonal returns to an AGP.
    Divin Dave,
    Jun 2010
    Central Indiana
    92
    Yes only 1 return which I thought was standard on agp? How would I add additional returns?
    What about running one of those Hayward auto pool cleaners such as the diver
    Dave? Would that work?
