Results 1 to 7 of 7
Thread: My test
    May 2009
    Kzoo Michigan
    4
    My test
    5/22/09
    FC 3
    CC .5
    TA 120
    Ph 7.2
    CYA was below 20 2 days ago added 2 lb of stabilizer
    Pool was green this spring shocked with 4 lbs of shock ran pump for 1 week straight then backwashed before i added CYA been running 12 hrs a day since my water is still cloudy cant see the bottom of deep end. I also added 22 oz of clarifier the same day i added the CYA do i need to run pump 24/7 and raise my clorine to shock level again? Also is my TA to high?
    AGP Dough boy 16x32 oval with deep end 16000 gallons
    Sand filter "Solar cover" TF100 Test Kit
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: My test
    .5 CC + cloudy water..yep, I'd raise it to shock and keep it there until I lost no FC overnight, and definitely run the pump 24x7. What's your CYA now, btw?
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    May 2009
    Kzoo Michigan
    4
    Re: My test
    Just added CYA 2 days ago think im going to wait till tmro to test CYA again going to add 2 gallons of 6% and 1 lb of shock is it ok to add shock and bleach together? I only have 2 gallons on hand
    May 2009
    Kzoo Michigan
    4
    Re: My test
    Updated Test 5/23/09
    FC 12.5
    TC .5
    TA 120
    CYA 30
    PH 7.2
    I just added 1 1/2 of baking soda to try and raise my PH
    Is my TA to high?
    Should i raise my CYA from 30 to 50?
    Pool is looking clearer and i am running pump 24/7
    Thanks for all your help its greatly appreciated
    Butterfly's Avatar
    South Carolina
    10,045
    Re: My test
    Quote Originally Posted by dandy327
    FC 12.5
    TC .5
    TA 120
    CYA 30
    PH 7.2
    Use baking soda to raise TA,not pH. Use Borax to raise your pH.
    Is my TA to high?
    No, looks fine. If you later have issues w/pH rising you could lower it then.
    Depends on your pool. If you have full sun, you may want to target 50, especially considering you will be backwashing w/your sand filter.
    Great!
    You're done SLAMing when:
    May 2009
    Kzoo Michigan
    4
    Re: My test
    Update 5/24/09
    FC 12.5
    TC 13
    TA 180
    PH was 7.2 added 1/2 box of borax will retest tmro
    Pool is still at shock level and is darn near crystal clear 3 24/7 days of pump running, when should i give it a rest like say 8 hrs a day cycle.
    IS my TA to high?
    When should i easy up on keeping it at shock level?
    How long before i can swim in it? Does the FC need to be down around 3ppm to safely swim?
    I'm going to retest my C YA tmro as well i added 2lb 4 days ago I tested it 2 days ago and it was 30.
    Butterfly's Avatar
    South Carolina
    10,045
    Re: My test
    Update 5/24/09
    FC 12.5
    TC 13
    TA 180
    You could cut back on the time to 8 to 12 hrs. if you need to, but it will take longer to clear your pool.
    IS my TA to high?
    It is okay if it is not pestering your pH to climb. Keep an eye on you pH & if you start needing to add MA too often, then you could look into lowering it.
    There is an article in Pool School with directions.
    You are done shocking when you meet these three criteria:
    1. Your pool is sparkly
    2. You hold FC loss to 1 or less overnight
    3. Your cc is .5 or less.
    Well, different opinions. We swim in FC that is below shock level for your CYA.
