Thread: Multi-port valve issue
    Apr 2016
    Lake Cormorant, MS
    4
    Hello all, I have been having issues when vacuuming my pool. When I vacuum, the insects and other small debris come back out of my return jet. I also hear a gurgling sound from my multi-port valve constantly. I took my multi-port valve apart and found the spider seal to be damaged so I replaced it. I re-installed the valve and I am having the same issues. I took the multi-port valve apart again and found what I believe are hairline cracks in the housing. i have attached pics. This is a Waterway valve. Has anyone ever seen this? Thanks.
    Jim
    IMG_20160618_141830146_HDR.jpgIMG_20160618_141837620_HDR.jpgIMG_20160618_141913805.jpg
    12K gal, Vinyl AGP, 1.5 HP Waterway pump, 26" Ecokleer Sand filter, Hayward Aquatrol SWG, TF-100 test kit w/SpeedStir, Taylor K-1766 Salt Test Kit, Dirt Devil D2500 Pool Cleaner.
    Casey's Avatar
    SW PA
    10,457
    Re: Multi-port valve issue
    Bumping for help.
    Jun 2012
    western NY
    1,562
    Hard to say if those are cracks or not.
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    Can't really tell if those are cracks or not. Do they appear to open up if you press on them? If not here are some other things you can do. Check the stand pipe and make sure it is not loose or cracked, check all the o-rings and apply silicon pool lube, and deep clean the sand filter to make sure the sand has not channeled.
    Love TFP? Become a
    TFP Supporter!
