Thread: Metal Magic with pool heater
    May 2015
    Syracuse
    6
    My sister opened her pool this year and found a huge stain covering the deep end. They didn't check their pH at all last summer, the water was so acidic it ate the copper in the heat exchange, which settled over the winter.
    They had a new heater installed - Sta-Rite SR333NA - and the pool store guy recommended Metal Magic to remove the stain.
    I'm guessing we don't want Metal Magic going through the heat exchange. My heater has a manual bypass, the SR333NA does not. There's a brief mention in the Sta Rite manual of a bypass switch. So my question is, does water flow through the heat exchange when the heater is off? Or do I need to manually bypass the heater while we're using Metal Magic?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,504
    Re: Metal Magic with pool heater
    Metal magic won't hurt the heater. It may not lift the stain either. It is a sequestrant and binds to metal in the water. If it doesn't lift the stain then ascorbic acid is usually the best way to lift the stain. Ascorbic Treatment to rid Pool of metal stains
    May 2015
    Syracuse
    6
    Thanks pooldv- if I use ascorbic acid, or Jack's, do I need to be concerned about the heat exchanger?
    DFW, TX
    24,504
    No, not as long as you keep PH 7.0 or higher. Preferably 7.2, but a dip to 7.0 for a bit is OK. Jacks won't hurt it at all. In fact the only thing that could hurt the heater is low PH.
    ps0303's Avatar
    Jul 2011
    FL
    3,703
    Quote Originally Posted by mpr5231 View Post
    An internal bypass which all units have is not like an external bypass of which you can add to your plumbing. The internal bypass just allows for excess water to flow back to the pool but it does not prevent water from going thru the heater like you can do with an externally built one. An externally built one allows you to isolate the heater so no water flows thru it at all. That's the best thing ti have if you need to perform aggressive stain treatment of resurfacing that might require and acid wash.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
