Thread: DH added "clarifier" without asking, now sand filter not filtering
    Jun 2008
    western Wisconsin
    250
    Ugh. DH added about 12 ounces "clarifier" (cationic polyamine solution and N-Alkyl Dimethyl Benzyl Ammonium Chloride) to our 26,000 gallon pool. (I might add that he did this without running it by me first.) His intention was to get rid of the pollen we have in puddles on the pool floor. However, now the sand filter seems to be unable to filter out any pollen at all - all backwashing just comes out clear (whereas before, it would at least contain yellow pollen).
    Any theories as to what happened?
    And, how do I remove it? (I am concerned about it screwing up my water and causing skin burns.)
    26000 gal, in-ground, vinyl pool
    Hayward S200 sand filter, 1 skimmer, 2 returns
    BBB since the first month! :-)
    JoyfulNoise's Avatar
    May 2015
    13,247
    Re: DH added "clarifier" without asking, now sand filter not filtering
    ADBAC is just the cheap linear quat algaecide (it acts as a clarifier too) so it's really not going to cause you any harm. Can you vacuum the pollen up to waste? How has your filter pressure responded? Did it go high and then recover after backwashing or did it stay high?
    You can always disassemble your sand filter and deep clean it as TFP does recommend doing that annually to ensure that the filter's sand media is not channeled.
    Matt
    Jun 2008
    western Wisconsin
    250
    Filter pressure didn't change, and water did not get clearer. I think the pollen did pool a bit more. I was able to vacuum most of it up this morning. Tried deep cleaning the sand filter and now it leaks, but I will post that in another thread.
