Thread: Help confirming Sand Filter Size - Pentair TA40D and 12K IG pool
    Jun 2016
    2
    I decided that I am tired of my cartridge filter, cleaning it is just too much of a pain so I put it off longer than I should, and the lid has decided that it only wants to seal in 1 position that seems to change with every lid removal.
    I have decided that I want to go to a sand filter. From my research it looks like a Pentair TA40D will work for my pool, but I wanted to check with the experts here to make sure that I would be sized appropriately.
    I do have a little height constraint that the wall near the pool equipment is 38.5" tall and I would like to stay below that (ideally a little below so I can make a solar shade too), going up to a TA50D will be too tall. I also looked at the Triton TR50 side mount filter, but I am not sure that I am getting another ~$200 worth of performance out of it.
    Will I be happy with the TA40D?
    Other notes:
    - I currently only chlorinate through floaters and plan on maintaining that.
    - I have to re-plump everything aft of the pump for either filter so that is not a big deal.
    - Currently the pump to filter plumbing is 2", it looks like most of the filters in this size are 1-1/2", I am planning on just necking that down right at the filter
    12K IG Pool, 1.5HP EcoTech EZ pump, On roof solar with separate pump.
    38,463
    Re: Help confirming Sand Filter Size - Pentair TA40D and 12K IG pool
    Welcome to TFP, neighbor!!!
    Sorry for the late response ... busy season made your post slide off the front page.
    For a 12k pool, I would suggest a minimum of a 20" diameter filter. So looks like the TA40D is right around that.
    Regarding your notes:
    1. Continued use of floaters (trichlor tablets) in Tucson is a very bad idea. The CYA is going to build up and require you to replace water yearly.
    2/3. Use 2" pipe and fittings everywhere you re-plumb and only reduce at the filter as needed.
    Have you discovered Pool School yet? Start with these:
    ABCs of Water Chemistry
    Recommended Pool Chemicals
    How to Chlorinate Your Pool
    Jun 2016
    2
    Thank you for the reply,I have been reading the "pool school" for several years now and recommend this site to any pool owners I find, I had been using liquid chlorine, but I suppose I got lazy.
