Thread: FC loss question
    paulmaz's Avatar
    Apr 2016
    San Antonio, TX
    114
    FC loss question
    This may be a dumb question, but is the FC loss from 20-18 the same as from 9-7?
    -Paul
    15k gallon IG plaster, 26x39 at widest points, sort of shaped like the great state of Texas!
    B2854 Pentair Challenger 1.5 HP single speed motor
    Tagelus TA-60 Sand Filter, Polaris 280, TF-100
    JoyfulNoise's Avatar
    May 2015
    13,204
    Re: FC loss question
    Depend on the CYA level. If the CYA is constant, then no, the FC loss rate is higher at higher FC/CYA ratios.
    Matt
    mas985's Avatar
    Pleasanton, CA
    11,737
    Depends on what you mean by the same. It is the same in that the loss is 2 ppm of chlorine for both cases and you would need to add 2 ppm to get back to the original values.
    Mark
