Thread: Plaster Crack /Roll Eyes
    Apr 2009
    Phoenix AZ
    11
    I am assuming based on my recently gained knowledge from this site that I have had a CSI issue for quite some time and this morning while out there checking my chem levels I noticed about a 3" x 1" plaster piece that has cracked off of just under the corner of my second stair going down into my pool. Is this something that a fairly handy person can/should try to repair or is it time to bring in a professional?
    My Pool - 21,000 Gallon Plaster In Ground Manatee Shaped Diving Pool - Sta-Rite Dura-Glas Pump 1 1/2 hp, 3450RPM, 48Y Frame, 230/115 Volts, 60hz., 9.6/19.2 amps - 24" Jacuzzi Bros Sand Filter 60 GPM (46 Backwash)
    30,402
    Re: Plaster Crack /Roll Eyes
    Hi, again, Zep,
    based on your description of the location, it most likely cracked because there was some movement of the surfaces at that point. If that movement has stopped, it can be patched by anyone fairly well.....assuming you can get a color match.
    If that movement continues, there aren't enough professionals in the US to keep it from cracking again.
    Apr 2009
    Phoenix AZ
    11
    Movement as in the earth moving, water moving around it, or movement of peoples feet on it? Considering it has stopped moving would a Leslie's pool store have some plaster patch? Not really concerned about the color match as much as I am having the plaster continue to break off and turn into something much much worse. BTW Great name there David!
    DL
    Apr 2009
    Sarasota Florida
    143
    Quote Originally Posted by Zepol
    DL
    ya i have the exact same problem. Mine is coming off of the top of the steps and right below the waterline tile. I think previous people had the chems way out of wack. Temporary fix would be good until i get it refinished.
    Kidney shaped ~ 10000 gallon Ig Plaster pool with pool cage. 120sf Cartridge filter. Pentair WhisperFlo WFDS-26, 230 Volt, 7.8/3.0 Amp, 1-1/2 Horsepower 2 speed pump, Solar panels on the roof. Heliotrope HelioMatic 4000D solar controller.
