Thread: pump kicking off
    Jun 2016
    ellenboro nc
    4
    pump kicking off
    Posted under wrong topic but. Pentair pump for above ground pool. Normal conditions pump trips breaker after 30 seconds and doesnt sound like it running full strength. With valve on closed, pump sounds normal and doesnt kick breaker. Its like no water, motor sounds strong, with water it kicks breaker. And ideas. Thanks.
    Jun 2012
    western NY
    1,563
    Re: pump kicking off
    Could be a bad run capacitor (if the motor has one) Is this a current setup that just started doing this or is it a new pump?
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jun 2016
    ellenboro nc
    4
    Its just started. Pool and pump are about 6 years old. Not sure where the capacitor is.
