Thread: Compool CP3600 problems
    Jun 2016
    San Antonio, TX
    5
    I have a compool cp3600 and occasionally I notice that the program settings show a garbled time and when that happens I notice that the programs that I set are not working and other things such as the waterfall come on at odd hours. I am frequently having to reset everything and reprogram. I am also having problems with my spa blower starting and staying on. Sometimes I can turn it on and it will work for a little while and then shut off and not go back on.
    M3Collins
    IG pool/spa installed 2002, 16,500 gallons, Plaster, Tagelus TA-100D Sand filter (2011), Pentair Dynamo pump, Polaris Spa and Water feature pumps, SWG - Aqua Rite T-15 cell, Pentair 400 heater
    ps0303's Avatar
    Jul 2011
    FL
    3,703
    Re: Compool CP3600 problems
    I wonder if the battery inside is going out. The battery keeps all programming when the power goes out but the battery can affect the display sometimes. Also, do you have a spa side remote?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Jun 2016
    San Antonio, TX
    5
    I haven't checked the battery but will try replacing it to see if that helps the programing. I do have a poolside remote. I had an electrician come out and my spa blower motor is bad.
    ps0303's Avatar
    Jul 2011
    FL
    3,703
    You might have to do the Compool to Easytouch upgrade.
    Paul
