Thread: Leaking chlorine feeder...
    Apr 2015
    Long Island, NY
    54
    Hello All,
    The image below is of my Hayward CL200 chlorine feeder and the coupling where a pretty significant leak was discovered. The threads and coupling, as well as the feeder itself are pretty worn from age. I have tried using teflon tape around the fitting threads to stop the leak to no avail.
    Here's my problem. I'd just as soon eliminate the feeder from the system and replace it with a straight run of pipe but, as you can see in the photo, the female half of the coupler is smack up against the elbow that turns south and into the ground and goes to the supply (skimmer, I assume) and there's not but a smidgen of a PVC pipe nipple between the coupling and the elbow. Obviously, the parts are cemented together and I'm at a loss as to how to solve this problem.
    Unless there's a way to separate the small PVC nipple from the elbow I need some advice on what to do to solve this quandary.
    As always, any suggestions would be greatly appreciated.
    In Ground 17,500 Gallon Freeform Vinyl Liner - Hayward S220T Sand Filter - Hayward Super II Pump - Kreepy Krawly Kruiser Cleaner
    If I had a dollar for every time I told my wife that there's no way we're buying a house with a pool, I'd have enough money to install the pool that came with the house we bought!
    Jun 2014
    15,235
    Re: Leaking chlorine feeder...
    I think if it were me, I would probably dig down just enough to remove that elbow as close as I could then replace that area. If I had to go a little deeper then I would. Maybe then consider installing a union if I ever decided to add something again later to avoid cutting as much later. As a last-ditch alternative though, have you tried any plumbers goops or something other than just Teflon tape? I can't remember the name of it but there's another pool putty product that many people use for threads, but I'm having a "senior moment" right now and can't remember its name.
    Qwaxalot's Avatar
    Jun 2012
    439
    You can't really fix a union with tape. In this case it looks like the union is missing its o-ring (goes between the black part and the tan part of the coupling).
    Or you can dig it out.
    In the industry, CSP (Certified Service Professional) by the NSPI and it's successor the APSP. My company services over 600 pools every year. I think the practices regularly espoused on this forum (especially the BBB method) are outstanding; however my comments will be often oriented towards the goal of getting it done, and getting it done right now!
