Thread: Cya measured by chlorine?
    Jun 2016
    Vermont
    1
    I've tested my CYA using the test kit. I find it far too subjective as it just depends on the lighting to make the black dot disappear. I was reading here that the higher your CYA the more chlorine was needed and if it was too high it wouldn't even measure.
    So is this a valid way to know CYA is dialed in? I had zero chlorine. CYA was somewhere measured 50 to 80. Pool calculator indiacted I needed 9.5 cups of bleach to reach 4.0. I added that amount and chlorine was tested exactly 4. So I assume my cya is good as if I had too high of cya the chlorine would have measured lower or not at all? Perhaps I misinterpreted the article I read. My main concern is that CYA is too high at this point.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,655
    Re: Cya measured by chlorine?
    The amount of CYA in your water has NO effect on how much FC is measured. If your CYA is zero and you add 4 FC, it will still measure the same 4 FC if your CYA was 80 instead. But do realize that a higher CYA level requires a higher minimum and target level of FC to be maintained for it. Welcome to the forum.
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    The role of CYA is to reduce the amount of FC lost due to sun/heat/etc. While a slightly higher FC level is required, it will be consumed less quickly.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
