Results 1 to 7 of 7
Thread: TA off chart during Slamming
    Jun 2016
    New York NY
    4
    Hi Gents,
    second day of SLAM and TA this morning was literally unreadable.
    FC 18
    CC 1
    CYA 50
    CH 50
    TA 1300 and I stopped counting the drops.
    I didn't check the PH cause I'm sure it will be unreadable too
    I'm using Clorax 8.25 % for slamming.
    What should I do next? Refill or using dry /muriatic acid?
    17000 gallons,16x32, IG, Hayward sand filter, Hayward 1.5 HP pump, using K-2006 test kit, Pool Math
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: TA off chart during Slamming
    Welcome to TFP!
    I would focus on completing the SLAM before worrying about pH or TA. After the SLAM and when FC drops below 10 ppm, then you can retest and adjust these parameters.
    You are correct! Wait until after the SLAM to retest pH and TA, then post the results here.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Hi Enzo,
    the high FC can really mess up the tesing. If you're slamming, don't worry about testing anything other than FC and CC. Just take care of the slam.
    Once the slam is over, and the FC drops down to more normal range, test and adjust then.
    Divin Dave,
    Jun 2016
    New York NY
    4
    Thanks for all the reply. ....I will finish the SLAM and report the results.
    Jun 2016
    New York NY
    4
    This the results of this evening test:
    FC 9
    CC 0.25
    CYA 40
    PH 7.2
    TA 100
    The water seems in good shapes ..let's see what the numbers say in the morning.
    Jun 2016
    New York NY
    4
    8:00 AM test
    FC 15
    CC 0
    TA 80
    CYA 35
    PH 7.2
    CH 50
    Being this my first year with this kind of approach , I want to make sure that the SLAM is done and as soon the FC gets within the recommended level I'm good to go.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    There are 3 criteria to pass the SLAM as shown here, SLAM
    Once those are passed then it safe to swim when
    PH is between 7.2 and 7.8
    FC is between minimum and shock level for your CYA, FC/CYA Chart
    And the water is clear
