Thread: Replacing bottom plate on Caretaker
    botanica37's Avatar
    Feb 2009
    Oakton, VA
    Does anyone know how hard it is to replace the bottom plate on a Caretaker? Is this DIY or I need a plumber or is it a pool service job? Any tips what to watch for?
    free form 40k gal, IG, plaster, Triton II 100C sand filter, Lite 2 heater
    1 1/2 HP Pentair Ultra Flow High Performance pump
    Caretaker in-floor cleaning system
    Mar 2007
    Coastalish 'down easter'
    Re: Replacing bottom plate on Caretaker
    I've installed ~ 30 of them but never had to replace the bottom plate. However, it's just simple PVC plumbing 8)
    All you have to do is cut all 5 lines at the same height and couple on to them and use 5, same length stubs if pipe to attach the new plate
    If you need any more on the 'How To', let me know
    Luv& Luk
