Results 1 to 11 of 11
Thread: Pool Depth: New Pool in PA
    Jun 2016
    Wexford
    3
    We like to hang out, play basketball, play volleyball. However, we also like to jump into the pool and swim under water in a deeper area. Depth is tough decision. Pool will be 38 x 18. Right now we are going with 15 feet of length at 3.5 feet of depth. Then 15 foot length of slope to 6.5 feet depth. Then about 5 feet flat at the 6.5 feet depth before end of pool depth rises back up a bit over last 3 feet. Any thoughts, concerns, recommendations? Wondering if might be better with each end starting at 3.5 and sloping to about 4 feet at about 12 feet from ends. Then slope to 5.5 feet in middle. Thx!
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Pool Depth: New Pool in PA
    Welcome to TFP
    With those depths there should be no diving/jumping being done, there is minimum for diving and jumping and it will depend on your state I think... someone should be along that knows exactly what is required...
    I hope this helps
    Jun 2016
    Wexford
    3
    Quote Originally Posted by cowboycasey View Post
    Welcome to TFP
    I hope this helps
    Thank you.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Welcome to TFP!
    We are very happy with our play/sport pool. Except for the 3-1/2' part. It is way too shallow and nobody hangs out there. Not even 6 year old kids. Where kids like to hang out is on the benches around the pool throwing stuff at each other, jumping off, resting, etc. My next pool will be 4x5x4. It is easy for everyone to find a place to hang out in neck deep water, stand up and play volleyball, catch, whatever. It is deep enough to swim. We cannonball like crazy in 5'. 6' is just annoying, you can't dive, it doesn't make much difference with cannonballs and only LeBron can stand up there.
    Feb 2016
    Atlanta, GA
    145
    I grew up with a 18x36 3.5'-12' pool.
    All of our time was spent on the slope.
    3.5' is too shallow. I'd go with a 4' shallow end. (i am building a 4-5-4 pool based on these experiences)
    Also as mentioned 6.5' is a little shallow to jump in safely, even for kids, you hit the ground too quick.
    What shape is the pool?
    Mar 2016
    Chino Hills, CA
    190
    Our pool is also 38'X18'. It is 3.6'X8' and we have no complaints at all. We dive in ours all the time but then again it is 8' at the deepest part.
    30,000 Gallon Pool IG (Pool 18' X 38' / Spa 7' X 7') - Pentair IC40 SWG - (1) Pentair Intelliflo 2 VST Pump - Pentair DE FNS-Plus 60 Filter - Pentair Mastertemp 400 Heater - Pentair Easytouch 8 - Pentair Electronic valves - Pentair 5G Color LED Pool/Spa Lights - Pebble Sheen Mini Tahoe Blue - Auto Fill/Over Flow - Taylor K-2006C - Completion 3/2016.
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,237
    You'll hear 100 opinions on this one
    The one I've read most is people with shallow at 3.5' wishing they had 4' and I've not heard anyone with 4' wishing they had 3.5'. I'm sure someone will make a liar outta me, haha
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    DFW, TX
    24,485
    I love the 3.5 foot section in our pool! Nope.
    One more thought. Hold up a tape measure to everyone in the house to see where 3-1/2' hits you.
    Jun 2016
    Wexford
    3
    Quote Originally Posted by allinspector View Post
    Rectangle (so we could use the auto cover).
    Thanks for insights.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,814
    A few quick comments on the auto cover (I know this wasn't your primary concern). Hopefully you've come to terms with the cost $10-15K. And view it as a car. It needs routine maintenance and repair. But I do like ours regardless of those two things. A
    pulley broke last year (normal), something ate a 6" hole in it his winter, cover switch burned out last week, cleaned cover, and covers last about 7 years ($3-4K). Not trying to discourage you, just a PSA.
    On depth, exact same size rectangle with autocover here. 3-8 1/2'. Really 3 1/2 since the 3' is only for a tiny bit. With a 38' rectangle there is a lot of space. I've probably said the converse elsewhere, but today as I think about it, for our pool, the shallow part is fine. Over the years little kids do come over and it is nice to have the perfect height for all since we can spare the space. Kids grow but people coming to our pool all seem to have different age kids. You know, divorce, remarry, have more kids. Or they just never stop, or you have a work party or a church party with different demographics. Clearly no right answer. Only a best guess for your family and situation.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Zappafan's Avatar
    Aug 2014
    Hampton, IL.
    151
    I wish I had dug my 3.5' shallow end another 6" also. Being 6'4" I had the foresight to add in a ledge approximately 5' into our pool dug out of the slope on it's way to a 9' deep end. IMG_1854_zpsi5gv5tpq.jpg http://www.troublefreepool.com/threa...fan-Pool-Build
    17K Gallon,IG Vinyl,1hp Pentair Challenger,Pentair TA60 Sand Filter, Hayward Colorlogic,Re-lined 06-20-15, TF-100,SpeedStir,Lagunitas and Margaritas. Zappafan Pool Build
