Results 1 to 14 of 14
Thread: Converted from liquid chlorine to a Hayward SWG
    Jul 2015
    Poway, CA
    58
    Hello,
    So I installed a AquaRite w/TurboCell, for Pools up to 40,000 Gallons and added salt which I am now at a salt level of 3000. The pool store said to set my SWG at 70%, is that correct?
    This is a new journey for me and is there anything else I need to know on settings, SWG and a salt water pool?
    Thank you for your help!
    27K Gal, IG Plaster, Hayward EcoStar Variable Pump, Pentair DE FNS Plus Filter 24, Hayward AquaRite with extended life T-CELL-15
    The Pool Cleaner Sweep
    Build in 1969
    Water From City
    TF-100 Test Kit
    cowboycasey's Avatar
    Jul 2013
    Fletcher, OK
    3,353
    Re: Converted from liquid chlorine to a Hayward SWG
    you can start at 50% and run the pump 6 to 8 hours and check to see what you FC is at, if it's at your target your good if below add run time or go to 60%, try testing 2 or 3 times a day so you don't dip below FC level
    Jul 2015
    Poway, CA
    58
    Is there anything else (settings) I need to do on the control board? It has a 2900 number on the display.
    My cell is a TCELL940WP, is that the T-15?
    Also, the numbers on unit which I don't know what they mean.
    2900
    80
    26.8
    6.44
    73P
    -3000
    AL -0
    r 1.59
    t - 15
    Thanks again!
    Build in 1969
    Water From City
    TF-100 Test Kit
    Jul 2013
    Fletcher, OK
    3,353
    I have a curcupool so no idea on the hayward, someone may be by and know in awhile
    Jun 2011
    Long Beach, CA
    2,778
    Hayward T-15 cells are sized for 40,000 gallons.
    The amount of chlorine the SWG makes is controlled by the output% and the amount of pump run time, so both of those need to be adjusted to make the right amount of chlorine for your pool. You will need to experiment with both to dial the SWG in but I will give you a starting point based on 3ppm of chlorine in a day. Most pools use 2-4ppm of chlorine in a day during the summer.
    Since you have a VS pump you need to make sure that the pump is running fast enough to keep the minimum flow required at all times. You will have to experiment with the low end speed to see what is the cutoff speed for the SWG.
    For your pool size the SWG needs to produce 11 ounces of chlorine in a day to make 3ppm of FC. This would be a decent starting point for being in Poway. The cell is capable of producing around 22.5 ounces of chlorine in a day so you just need to do some math to get the required 11 ounces which is about 1/2 of the capable output of the cell. So a starting point would be 12 hours of run time and the SWG set to 100%.
    Measure the FC each day to see how the pool is doing and adjust the pump run time and/or the SWG% as you see fit.
    Water Balance for SWCGs for extra credit.
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Another item to consider... for plaster pools you need to raise your CYA level to sustain 60-80 for your SWG. A full test kit result - NOT THE POOL STORE - will be your best friend in trying to get your SWG set correctly.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    Jun 2011
    Long Beach, CA
    2,778
    Quote Originally Posted by Imracerx View Post
    2900 average salinity
    80 temperature
    26.8 voltage
    6.44 amps
    73P output percentage
    -3000 instant salinity reading
    AL -0 AquaRite automation setting
    r 1.59 board revision
    t - 15 cell size
    Thanks again!
    added text to the numbers above
    Jul 2015
    Poway, CA
    58
    So is the TCELL940SWP the T-15? I want to make sure.
    Quote Originally Posted by ping View Post
    "Water Balance for SWCGs" Wow, this is an eye opener!
    CYA to 70-80, I am at 40 right now.
    CH is 475 which it mentions that I need to be at 350, but I just RO last year.
    TA is at 110 and I need to be at 60-80. To lower reduce TA it says to lower PH to 7-7.2, but it also mentions if I add CYA it can also lower PH as well. So what is the correct way to get TA to 70 and PH to 7.5-7.6?
    I have Soda Ash, Muriatic Acid and Alkalinity up on hand.
    Thank you,
    Build in 1969
    Water From City
    TF-100 Test Kit
    Saturn94's Avatar
    Mar 2015
    Virginia
    496
    It looks like that's the extended life cell for pools up to 40k gal.
    20k IG vinyl liner/Aqua Rite SWCG, T-15 cell/Hayward Pro Grid 6020 DE filter/Polaris 280 with booster pump/Hayward Superpump 1 hp/city water/pool installed March 2004
    Jul 2013
    Fletcher, OK
    3,353
    MA, drop your PH down to 7/7.2 and let drift back up to 7.5 and do it again, you can add a waterfall or turn you returns toward the top of the water
    Jun 2011
    Long Beach, CA
    2,778
    TCELL940SWP is the extended life T-15 cell.
    Jul 2015
    Poway, CA
    58
    So this will bring the the TA down to 70? Just to be clear.
    Build in 1969
    Water From City
    TF-100 Test Kit
    Jul 2013
    Fletcher, OK
    3,353
    It can, you have to bring PH down, then test TA to see where you are at
    Jun 2011
    Long Beach, CA
    2,778
    Here is the process on lowering TA found in Pool School, Lowering Total Alkalinity.
    Don't worry about the CH right now as it will continue to rise above the suggested range. What you will need to do is keep the pH in the lower 7's once the CH gets in the 600 range.
    For now getting the TA down to 60-70 will keep the pH from rising quickly. There are major benefits when operating a pool with a SWG and keeping the TA around 60.
