Thread: Hot Tub blower
    Hot Tub blower
    Hey everyone,
    You guys and gals do such a good job on this forum that I am becoming pretty much self-suffient in the pool area! Thanks. Now we are working on the hot tub! Last fall pulled out the air blower and got this off the unit. Air Pump, 2.0 peak, 4.4 amp, 220V 60HZ, 104 CFM 100 in. of water @ MLS 4.1 PSI. This was a metal blower which rusted away. Looking to replace and thinking all this means I need is a 1.5 or is it a 2HP, 220V blower? Are the plastic as good as the metal blowers? Is 210 or 240V the same as 220V? This is a stand alone tub that shares the 2hp pump, sand filter and heater with the pool. Any help would be appreciated. Thanks Kay
    26,000 Gallons in ground with spa
    Jandy equipment
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    Re: Hot Tub blower
    Sounds like we have a fairly similar setup with the spa sharing water and equip. with the pool. Would you mind posting any pics of yours and maybe the equip./plumbing too?
    If you had a 2HP blower before and it worked well, I'd replace it with the same. 210-240 should all be the same. Plastic if fine as long as you buy a blower made to be used outdoors. The type that is designed for a stand-alone tub is usually not weather-proof, so make sure you get an outdoor unit that is.
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
