Thread: oops!
    Jun 2016
    Garden city
    2
    oops!
    I added washing soda to bring my alk. up. Three hours later I added calcium chloride to bring up the hardness.. I just read to never, never add these two on the same day. The water is "new," following a drain/ re-fill this past winter. It now has a dull, almost cloudy appearance. Will this correct itself over time or is there a course of action I need to take? If it will clear on its own, how long does it generally take? And what exactly happened?
    Thanks for any info and or advice.
    FC 6
    TC6
    PH 7.6
    TA 100
    CH 210
    CYA 70
    TEMP 82
    Charleston S.C. 5500 gal. plaster inground Hayward starclear 1200 cartridge filter, 3/4 h.p. superpump, small waterfall
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: oops!
    Yes, adding calcium chloride often clouds the water and will clear in a day or two.
    Jun 2016
    Garden city
    2
    Re: oops!
    Thanks, that was the answer I was hoping for!!!
