Thread: PVC Pipe for Solar Install
    Jun 2007
    Charleston, SC
    151
    Wasnt sure if i should put this in this forum, or the "Everything Else", but here goes anyway.
    I'm planning my solar install and in doing research, have noticed a lot of people using black pipe for thier install. It looks much better than the white PVC, but if I am not mistaken, isnt the black pipe ABS drain pipe?
    Can you really use that for plumbing a system under pressure? I always thought that was a no-no.
    Any advice/info would be appreciated.
    18' Round ABG (8000 gallon)
    Hayward X-Stream Cartridge Filter
    1.5hp Hayward PowerFlo Matrix Pump
    80 sq. ft. solar panels
    Goldline automated solar controller
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: PVC Pipe for Solar Install
    You shouldn't use ABS pipe for pressure applications plus the connections between ABS and PVC require special care.
    There is black PVC but it is hard to find and I believe it is expensive as well. It is easier to use white PVC and then just paint it with a decent plastic paint.
    CPVC is also and option and holds up better for high heat applications (Az, CA central valley, etc).
    Mark
    Jun 2007
    Charleston, SC
    151
    Thanks, you confirmed what I thought.
    Ill continue on with the white PVC + spray paint plan
    Guest
    Black ABS is thin wall too, so it cannot handle the pressures associated with the system.
    Definitely good with Sched 40 PVC.
    Could use CPVC (Thompson Gold?) if it is available in your area. More expensive too. CPVC was just approved for use in CA now.
