Results 1 to 8 of 8
Thread: Floating a Puck or 2
    Jul 2015
    Edgewood, Texas
    101
    I will be gone for about a week and hoping to not come back to a swamp ....
    Numbers tonight at 9:50:
    FC 3.5
    CC .5
    CH 75
    TA 100
    pH 7.5
    CYA 60 (a week ago, it was too dark to test)
    My pump/filter and SWCG will be off during this time for the most part. I do have someone that will look in on the pool from time to time, remove debris if needed and maybe run the pump/filter some. They can possible added some bleach, but it will be guess work.
    My plan tonight is to raise FC to 10 by adding 62 oz of bleach and putting a couple of pucks in the floater.
    Any thoughts?
    Intex Ultra Frame AGP (18x48; 6,423 gallons)
    Intex Krystal Clear Sand Filter Pump Model SF80110
    Intex Krystal Clear Saltwater System Model CS8110
    TF-100 Test Kit with SpeedStir
    K-1766 Sodium Chloride (salt water) Test Kit
    Pool Tool's Avatar
    May 2014
    Western Chicago Area, IL
    757
    Re: Floating a Puck or 2
    First thought, your fc is a little for CYA of 60. Second thought, why will pump and SWG mostly off? That's the beauty of the SWG is letting it do it's thing while your away.
    16' x 32' (21100 gal), vinyl, 1.5 hp Hayward SuperPump,
    Tagelus TA60/60D Sand Filter, Raypak 399K Digital Heater, TF-100
    Pool Tool's Avatar
    May 2014
    757
    FC is a little low, sorry not as fluid on the phone.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    I would suggest running the pump and SWCG while you are gone. This is one of the major advantages of a SWCG pool - it will generate chlorine for you while you are gone, provided your salt cell is in good shape and the salt level is in the recommended range.
    If you go solely with the high dose of bleach and a couple of pucks, you are risking FC dropping too low over a week's time, especially during June in Texas. The sun will be at its highest point in the sky over the northern hemisphere during the next week or so, meaning longer days and more intense UV rays. In addition, we are currently experiencing the first real heat of the season. This results in the highest rates of chlorine loss due to sunlight of the entire year. For example, if you start off with 10 ppm of FC before you leave and lose 30% of FC per day, it will be at around 1 ppm when you get back assuming no further additions are made. The pucks will help, but they are unlikely to fully dissolve over the course of a week and therefore will not release all of their chlorine content. Having someone add chlorine will help, but I would suggest providing them with some guidance on how much to add.
    Jul 2015
    Edgewood, Texas
    101
    I have been having an issue with my pump/filter. I would like to leave it on (via timer) but when it comes on it doesn't pull water so I have to backwash or close the plunger valves and re-open then turn on the pump/filter. I can't run the risk of it coming on without pulling water and with no pump, that means no SWCG. Our pool is almost completely shaded all day so hopefully that will help. My dad will be checking on the pool and hopefully I can guide him through adding bleach at least a couple of times during the week. He also has a pool, but he uses the pool store method. He says he is changing to the TFP method when I return and can help him out.
    Mar 2012
    Mountain Brook, AL
    112
    If he can add some during the week you should be in good shape. If he could prime and run the pump for a day that would be even better. Maybe you could walk him through it by phone. All of that is good motivation to get it running correctly. I hope it goes well for you.
    13,500 gallon IG Diamond Brite Super Blue, Pentair Superflo 1.5 HP 2 speed pump, 300 lb Hayward Sand Filter, Hayward Swim Pure+ SWG, Four 4X20 Fafco Solar Bears, Jandy Lite2 NG Heater, Borates, Blue Diamond Robot, TF100 & Refills, Taylor SpeedStir
    Jul 2015
    Edgewood, Texas
    101
    Thanks everyone for the replies.
    Every time I think I have things running smoothly something else causes an issue. We just installed the new pump/sand filter last weekend (had a small cartridge filter and our city water has too much iron in it). It has definitely cleared our water from the iron, but little things just keep testing my POP!
    Jul 2015
    Edgewood, Texas
    101
    The pool survived! My dad came over Tuesday night and ran the pump/sand filter and added about 8 cups of bleach. I got home a day or two earlier than planned so I was able to start the pump/sand filter and SWCG this morning and removed the floaters w/ pucks (they had not completely dissolved).
    My family had a nice swim after I vacuumed and brushed!
    I will test tonight and adjust accordingly.
