Thread: Calcium??
    May 2016
    Central Arkansas
    8
    Calcium??
    So mine is like 90. I have calcium chloride flakes from the previous owner, will that be good to use to raise my calcium hardness?
    18.5 x 33 x 4 Oval, Above Ground, Vinyl Liner, Sand Filter K-2006 Test Kit
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Calcium??
    Welcome to TFP.
    Since you have a vinyl pool, you do not need to worry about adding calcium. That is one of the advantages of a vinyl liner. Plaster surfaces and, to a lesser extent, fiberglass do need some calcium. However, vinyl does not.
