Results 1 to 8 of 8
Thread: Painting concrete deck.....
    Feb 2008
    Milford, CT
    333
    I need to pressure wash my concrete pool deck, and it got me thinking I might want to paint it (better color, maybe even easier to clean).
    Has anyone done this? Note my pool itself is not concrete (vinyl IG), just the "deck" around it.
    Any product suggestions?
    Thanks.
    -Chris
    22K IG vinyl, .5HP Northstar pump, S244T filter, AutoPilot Digital w/SC-48 cell
    Aug 2008
    Southwest New Hampshire
    52
    Re: Painting concrete deck.....
    Personally, I have never liked painting concrete, especially exterior concrete. Once you paint it, you can't go back. It can peel and be a real headache down the road. Not sure what yours looks like, but maybe a power wash and then clear sealer coat.
    Andrew
    25,000 gal IG Vinyl - PoolPilot SC48 SWG - Sta-Rite 1HP/System3 CF - AquaCal HeatPump - TF-100
    Feb 2008
    Milford, CT
    333
    Quote Originally Posted by andrewg
    Mine is a nice....concrete color Seriously though, its probably something that was colored in the concrete itself, as there is a slight tan tint to it.
    I need to patch some cracks first, and figured the patches would never match correctly and maybe painting would be an answer, but maybe not. Wonder if I can go with a colored sealer that might be able to match the patches up a little better.
    stever's Avatar
    Nov 2007
    Escondido, CA (near San Diego)
    285
    Quote Originally Posted by chrisexv6
    careful with the sealer -- very slippery. I have had the 'grit' put in it twice in 2 months and it's still a bit slippery. It has a texture, but beads the water so much it's always wet.... not like a basic sand-blasted concrete that the water soaks into.
    Steve
    Pool: 625 SF Free-Form In-Ground Shotcrete Pool w/7.5' dia spa.(8 jets), 24" raised bond beam (22,500 gal)
    Pentair Equip: Intelliflo VF Pump, MasterTemp 400 Heater, IC40 SWG, Quad DE 100 Filter
    Automation: IntelliTouch i7+3 (+ extender panel), 6 Jandy Automated Valves (S, R, Spa Bypass, Solar, Cleaner, Spillway)
    Other: 75% Solar, Kreepy Kruiser Cleaner, Tan Hip-Hop Diving Board (a bit curved) on 606 Cantilever Base (SR Smith)
    Links: [TFP Pool Build Thread] - [TFP Landscaping Thread]
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    I suggest you consider THIS.
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    Sallie's Avatar
    May 2008
    Columbia, SC
    103
    We used Patio Tones a few years ago, and it worked great and has held up. There are several colors to choose from. We did the prep work that was recommended and rolled it on. We have a large deck area, but it was no big deal, and I'm a very particular painter.
    Sallie
    25 K gal., vinyl IG, Hayward 3/4 hp pump, Hayward Pro Series S-220T 18" sand filter, full sun all day, no main drain, Taylor K-2006C and K-1766 test kits, Circupool RJ45 SWG - Columbia, SC
    Feb 2008
    Milford, CT
    333
    Any tips on doing all the steps without destroying the pool chemical balance?
    TSP, muriatic acid, paint all close to the edge of the pool.......
    Sallie's Avatar
    May 2008
    Columbia, SC
    103
    I remember that we used TSP, don't remember about muriatic acid, but it's been a while. Anyway, no tips about keeping it out of the pool. In many places, our deck slopes toward the pool, so we did have stuff go in there. We were careful, but there was no way around it.
    Sallie
