Thread: Chlorine test to use less drops when checking high chlorine leve
    Oct 2010
    michigan
    284
    Chlorine drop test. With powder.
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Chlorine test to use less drops when checking high chlorine leve
    Are you using the 25ml or the 10? You can use 5 and count each drop as one. It's not quite as accurate, but works as long as it's not for an OCLT.
    Oct 2010
    michigan
    284
    My kit uses the 10mil instructions
    So i can use 5mil and use the same 1 heaping scoop?
    Oct 2010
    michigan
    284
    Just did the test twice,
    5mil. 17x1. =. 17
    10mil. 27 x .5 =. 13.5
    Also you can be + or - a few drops to 5mil or 10mil mark
    38,475
    Small volume variations cause a larger error when the sample is smaller.
    We generally do not recommend the 5ml test method ... Even if many members seem to suggest it to save a few pennies.
    domct203's Avatar
    Jun 2015
    CT
    3,596
    +1
    A 2oz bottle of R-871 is $11, at the advertised approx 140 tests per bottle, that's $0.08 per test.
    The added errors in using 5ml could lead to an algae bloom, where any savings in test reagent will be swallowed by the added chlorine cost to clear the algae.
    Dom
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
