Thread: Sand filter humming!
    Jun 2016
    Autryville nc
    4
    I have a new Intex Krystal Clear Sand Filter Pump for Above Ground Pools, 3000 GPH Pump Flow Rate, 110-120V with GFCI and when we started it up, back washed it, and then turned off the switched to rinse. When we turned it back on it just had a humming sound and was not running water through it. Any suggestions. We are first time pool owners and have a Bestway 9'x18' rectangular pool. The sand filter has the saltwater system attached to it.
    MikeInNH's Avatar
    Sep 2007
    Southern NH
    476
    Re: Sand filter humming!
    It sounds like the motor is stuck. Anyway you can manually spin it with the unit unplugged from power?
    Mike
    2007 1st full year with AG pool~15k gallons 18'x33' JW
    6/2010 added 2 button Intex SWG-painless except for when reset
    Switched to BBB from Baquacil (couldn't pay me to go back)
    Jun 2016
    Autryville nc
    4
    Will try that tomorrow
    Kellie
    NC Salt Pool
    Piolin's Avatar
    Sep 2010
    Miami, FL
    604
    Mine was making noise and I had a one year warranty, so I called Intex and they sent me a new one, now the old one is waiting for me to change the bearings, take a look at YouTube for instructions on how to do it...
    8,400 gal Intex, 3K GPH pump, 16" sand filter, SWG CG-28669, TF100 test kit, speed stir, K-1766 Taylor salt test.
    The corner stone of TFP
    Pool School - Chlorine / CYA Chart
